Question about Pacific Laser Systems PLS5 Automatic Laser Plumb Level And Square
I have a PLS 5 Laser that does not turn on with fresh batteries.Where can I have it checked and repaired
Hi, a jus turn on my laser and i see green light on top of it but no beam at all.mabe i dont know how to use it?
The green LED on top is the power indicator. The PLS5 has 5 optic windows that should produce beams. Do Not look into the windows to see if there is a beam. Place your hand in front of each window. If there is no beam from any of the windows the unit is malfunctioning and requires service by an authorized service center. PLS states that there is NO service or repair that can be performed by the consumer beyond replacing the batteries and cleaning the optic windows This unit has a 1 year warranty from PLS.
Here is a link to the manual
http://plslaser.com/sites/default/files/PLS5&3Manual_6_2008.pdf
and to their contact page.
http://plslaser.com/content/contacting-us
Jan 04, 2011 | Pacific Laser Systems PLS5 Automatic Laser...
Leica disto classic 5a
the only thing which comes to my mind is that
the laser may have become weak ....
did u try with new batteries..
ne way the new ones also cant measure more than 200 m...
the device might be loosing its strength..(maybe that guy had used quite a few times)
Oct 22, 2008 | Leica DISTO A5 Rangefinder
Only a few hours after inserting a new battery (tried two different packs of NEW batteries) into my Microsoft 6000 wireless mouse, the red light on top comes on.
I use rechargeable batteries rated at 3200MAh and have been operating for 2 months now.
If you can't get hold of them, try fresh Alkaline batteries like Duracell.
pls. vote for better service... thank you
Nov 14, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Can't turn it on. Batteries are fresh.
Make sure or check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Check whether (Memory Card/Battery Cover) is properly closed. 3) Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust ) 4) Load new or fully charged battery.
5) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot S2 IS Digital Camera
Not turning on kodak 12mp v1253
Your camera is only compatible with: 5V AC adapter with power cord(s) for in-camera battery charging
Unfortunantly If you used 12V the repair will be OoW
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak Easyshare C182 12MP Digital Camera
Kodak Easy Share CX7330 turns on momentarily, does not extend lens,then turns off. Flashed a B02 message.
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Pls test with an alt. batt. Make sure that you are installing a fresh/ full charge battery
Remove the battery
This camera is no longer repaired. But KODAK offeres a Trade up. Where you for the exchange of your old cam can buy a new mmodel for 25-30% cheaper than market price.
Contact KODAK:
Nov 11, 2009 | Kodak EasyShare CX7525 Digital Camera
Wont turn on anymore. shutter goes in and out and screen wont turn on
Remove the battery
Contact KODAK:
Nov 04, 2009 | Kodak EASYSHARE Z1485 IS Digital Camera
Ready light keeps flashing red. Replaced with a new battery from Kodak today but did not fix problem. No picture in LCD.
If the correct recommended batt supplied from KODAK didn't solve the problem Then a repair is recommended.
Info on batt:
Remove the battery
Contact KODAK:
Oct 30, 2009 | Kodak EasyShare LS443 Digital Camera
Lens cover is not opening
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 16, 2009 | Kodak EasyShare Z885 Digital Camera
Kodak m863 camera will not turn on
Remove the battery
Contact KODAK:
Aug 19, 2008 | Cameras
Pacific Laser Systems PLS5 Automatic Laser Plumb Level And Square Logo
44 people viewed this question
Top Pacific Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
