Question about Hydrofarm Timer 24 Hour
Hi, I have your hydrofarm dual outlet digital
Hi, I have your hydrofarm dual outlet digital timer. I have everything set properly, but don't know how to get it to actually execute the program. I have tried it on both auto settings (a minute apart 1-ON 2-OFF). Nothing. Pleae advise!
  • Hydrofarm Master
  • 5,089 Answers
2 Suggested Answers
SOURCE: i have a hydrofarm 24 hour dual outlet timer,
Add a comment and post a photo of your timer so we can have close look at your do-it-yourself problem:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Dial has 48 segments.
Each segment represents 1/2 hour in 24 hour day.
Pull up 32 segments and leave 16 segments down.
Manually rotate dial and watch when light turns on-off.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 09, 2011
Setting a timer model hb88rc75
http://waterheatertimer.org/Woods-timers-and-manuals.html#HB
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Manuals for the Intermatic are located on links above.
If your timer does not show, then attach photo of product
If you have specific question about setting the timer, add a comment March 2015
Gene
Water Heater Timers Save Money
Mar 28, 2015 | Hardware & Accessories
Hydrofarm timer not working
Reset timer and reprogram, being careful to overlaps or conflicts in programming.
Is this new timer or timer that stopped working?
Which timer do you have?
Does timer have replaceable battery? Or internal rechargeable battery?
Copy following link for possible identification of product and manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Sep 20, 2012 | Hydrofarm Timer 24 Hour
I need the instructions for the Hydrofarm TM01715D Timer, please. :O)
Copy following link to identify same-similar timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#six
May 29, 2012 | Hydrofarm Hardware & Accessories
Can not set up my hydrofarm timer to come on for 1 min and off for 5 min.
You posted next to a photo showing hydrofarm analog timer with segments located on dial face.
Open following link for general look at setting analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Analog timers have a minimum set time of 15 minutes because the trippers-or-pins-or-segments are made certain width.
If you want 1 minute ON and 5 minutes OFF, you need digital timer.
Most digital timers have minimum set time of 1 minute.
But digital timers have limited number of set points per day unless you get into heavy-duty Intermatic timer like the ET70115 timer with 100 or so set points.
If you want 1 minute on and then 5 minutes off, and want to repeat that same cycle over and over throughout the day and night, you would need 240 set points.
Or check out 120V adjustable cycle timers.
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
If you want the cycle timer to operate certain hours only, then put ordinary 24-hour timer between the cycle timer and the load.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
Jun 05, 2011 | Hydrofarm Timer 24 Hour
I have a hydrofarm 24 hour dual outlet timer, analog, with 4 black segments, each representing 15 minutes,. I have read the directions over, and over and still dont know how to use the darn thing... i just...
Mar 09, 2011 | Hydrofarm Timer 24 Hour
I need instructions for hydrofarm tm 10105
Question posted under image of analog plug-in-type timer
Open following link for instructions how to set timer by experimenting with features:
Feb 07, 2011 | Hydrofarm Timer 24 Hour
Dual Outlet Timer won't shut lights off, even though pins are in the right place. Do you turn on the lights before attaching timer, or let the timer do that?
The timer dial should turn lights on and off.
The lamp switch has to be turned on for the timer to work.
It sounds odd that the timer will turn ON the lights but not turn them OFF.
Make sure your pins are pushed all the way into place.
With older timers, the pins wear out or the tripper lever wears out, and this could cause the problem you describe.
Nov 03, 2010 | Hydrofarm Timer 24 Hour
Ecoplus Digital 120v Timer Dual Outlet 24hr 7day Timer: my timer is not cutting on when i have it set to....
Make sure your timmer is set to "AUTO" mode and that your programed times/weekdays are good, resetting the timmer should solve your issue i've had it before, these timmers do this to me once and a while.
Make sure you dont have an "O" on the left of your time as this randomises off/on times by 2 to 32 mins. Press "HOUR" and "MINUTES" at the same time to toggle this option.
the timers manual can be found here:
Eco Plus Digital Timer
May 18, 2010 | Day-Timer Ecoplus Digital 120v Timer Dual...
Hydrofarm Timer 24 Hour Logo
196 people viewed this question
Top Hydrofarm Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hydrofarm Hardware and Accessory Expert? Answer questions, earn points and help others
