Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Printer (bizhub 350) keeps saying malfunction detected. shows code c-0500. what can i do?
  • 1,110 Answers
The C0500 code means that the fusing unit is not heating up properly. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. You are going to need to have a technician come out and diagnose the problem for you. Most common failure in the fusing unit is a blown thermal fuse. Next most common is a bad thermister, which is the part in the fuser that monitors or "reads" the fuser tempurature. Although rare you could also have a bad heater lamp. Removing the fusing unit and diagnosing which part is bad is not something I would recommend for anyone other than a trained service technician. At least you know what the cause is so you do not have to worry about getting mis-information from the service person. Such as if they say you need a new fusing unit. You just need the defective part replaced, NOT the whole unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 09, 2010
Malfunction detected c 3301
No such code for a Bizhub 350. What model is it?
Sep 19, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction detected c3451
gives the corresponding malfunction code and maintenance call
May 17, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
My Bizhub 350 is saying malfunction dectected C3452
This code means you have a fuser warm up failure. The fusing unit uses heat and pressure to "fuse" the toner onto the paper. It is located right where the paper exits the machine. Here is the info directly from the service manual:
The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Most likely you have a thermistor failure in the fuser. You are going to need to call your local service company and have them repair then reset the machine.
Sep 08, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Malfunction C-1116 for bixhub 420
this error code means the exit motor release motor drive has failed.
if you look on the left side of the machine where the finisher exit tray is where the paper comes out you will see a plate that is supposed to go up and down see if there is a small chunk of paper or something could be keeping the plate from moving
Nov 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 353p error c - 4551
Faulty door sensor?
Sounds like the door my be loose or mis-aligned.
Oct 03, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
147 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
