Question about Hunter 52" Ceiling Fan With Light And Remote Control
Ceiling fan remote not working
I am not able to turn my fan or light on anymore. Everything worked great with the remote and now it does not do anything. I have replaced the batteries in the remote and I have tested the power at the fan. There is no override to turn the fan on. Is it possible the receiver for the remote is bad at the fan? Any help would be appreciated. Thanks in advance.
Rich
  • 2 more comments
  • mike898 Jul 12, 2008
    remote works for light, but not fan
  • Pointe_Man Sep 01, 2008
    Well this is a very similar problem, I'm not sure I understand everthing that is happening.
    I installed 3 swithches in three locations, by the door as I enter the room and then on each side of the bed I have a switch for the light and the fan. So there are a 3-way switch by the door and a 3 way switch on the left side of the bed and a 4-way switch on the right side of the bed. I can say with some certainty that all of the wiring is correct. But after connecting the remote I can not do anything with the remote unless first I turn the light switch on. Then I can use the remote as it is intended. The fan switch now never works. If I have the fan and lights on, and turn the light switch off both the light and fan turn off.
  • charlyons114
    charlyons114 Dec 31, 2012
    i've had two remote controll ceinling fans stop working after kids pulled chain instead of using remote ii dont know fix yet but i know this happen with both fans
  • Anonymous Mar 25, 2014
    Hooked everything up all tested and worked good later tried to turn off light with remote had to use pull cord then later turned off fan with remote now nothing works tried replacing battery no luck
  • 20 Answers
It is certainly possible that the remote went bad -- after all, it is an electronic device, and is was "made in China". With that said, there are other possibilities:
* The receiver, which is what receives the signals sent by the remote control, could have died. In most remote-controlled fans, the receiver is located in the ceiling canopy (the decorative part up by the ceiling, which hides the wires). In other fans, it's located in the switch housing (the part of the fan to which the light kit attaches). Solution: try everything else on this list; if nothing works, replace the receiver. Universal replacements for most models are available at Home Depot and Lowes.
* A wire on that receiver could have come loose. Solution: check all wires for secureness.
* A wire in your wall or ceiling -- the wire which provides power to the fan -- could have come loose or been chewed through by a rodent. Solution: use a circuit tester to check whether there's power at the connections at the top of the fan, in the ceiling, where the fan connects to the building's wiring.
* A circuit breaker could have tripped or a fuse could have blown. Solution: check your circuit breaker or fuse panel.
* The DIP switches inside the remote control -- which set the frequency on which the control transmits -- could have been knocked out of position accidentally or by a child playing with it. Solution: check the code on the DIP switches on the receiver in the fan -- then, make sure the remote control has its DIP switches set the exact same way.
If none of the above work, then yes -- the problem is with the receiver or the transmitter (remote). The two are typically sold as a pair, and universal replacements are available at Home Depot and Lowe's.
Hope that helps! Feel free to ask for clarification if you need it!
Posted on Jun 17, 2008
  • 20 Answers
Remote control part #85094-02, Hunter Fan Co. stopped working after falling on tile floor.
It doesn't turn on not light nor fan. After inspecting circuit board there is no damage of components.
Pressing down any button lights up the red led, and no function either.
Thanks in advance for any help to solve this problem.
Chawah
Posted on Oct 13, 2008
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Model 740 154 Hampton bay Mediterranean ceiling fan
Make sure the switches in the remote and the receiver board inside the fan canopy are set to 3
Sep 06, 2009 | Hampton Bay 52 In. 5-Blade Ceiling Fan,...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote is not working and fan won't turn on
Take the fan down. Remove the blades, by pass everything, by cros wiring the fan using a plug in to see if the motor is working. If it works then you have a defective remote.
Jul 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote will turn on the light, but not the fan.
I have a white Westinghouse tv and can not programs the code in a Rca universal remote control
could you give me the code for the tv. Thank you
Nardin
Jul 02, 2009 | Universal Remote Control Hampton Bay...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dryers Logo
8,335 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
