How to avoid pressing green button when we print the documents? Everytime when I print I have to press GReen Button to continue printing on HP laserjet P2035n ?
  • 9 Answers
SOURCE: I have to press the tick every time i print
If you go into the printer config there should be an option for "manual feed." Turn this off and it should fix your issue.
Posted on Feb 21, 2008
BigdaddyTDW
  • 62 Answers
SOURCE: must push the green button to print
Strictly in the user settings from the PC side.
Posted on Feb 12, 2009
SOURCE: I cant scan on my F380
thanks
Posted on Jun 21, 2009
SOURCE: My laserjet p2035n will not stop printing. I am
I had the same problem running WINXP 32bit and WIN7 64bit Pcs with P2035n installed on home network. I uninstalled the printer and reinstalled with WIN7 64bit drivers. See Hp link below:
HP LaserJet P2035 and P2035n GDI Plug and Play Package
Posted on Mar 27, 2010
Open Devices & Printers --->
Highlight the P2035n, right click, and select 'Printer Properties' -->
On the Ports tab, uncheck the box 'Enable Bidirectional Support'
Posted on Nov 01, 2010
I have an HP 5500 color laser jet that is missing the cyan color when printing. I have replaced the print cartridge, contacts of high-voltage PCB, laser/scanner, high-voltage PCB and the DC controller,...
To fix this problem it is best to reset the HP Printer to its Default settings. Follow these Steps and This should fix your problem.
Step1: Turn the Printer on.
Step2: Watch the Control Panel on the printer.
Step3: When the Memory starts counting, press and hold the Green check mark button also known as select. Continue to hold Select button until all three Control Panel LED's are lit up and solid on.
Step4: Release the Green Check Mark Button (select)
Step5: The control panel will display SELECT LANGUAGE.
Step6: Press the Down Arrow until the control panel displays COLD RESET.
Step7: Press Green Check Mark Button (select). The Printer will perform a cold reset and then continue its power-on sequence.
Apr 29, 2011 | Office Equipment & Supplies
Sent a document to print but its not printing and the printer light keeps on blinking even though I've unplugged the printer twice and even rebooted my system?
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Hopefully, this will fix the problem for you!
Nov 23, 2010 | HP DeskJet 3550 InkJet Printer
My HP Laserjet 4350 is printing 3 copies all the time even the test page.
Press the green button (with the "check" sign on it), then press the "down" arrow button four times.
The display should read "configure device".
Press the green button again.
Press the down arrow one time? until you see "printing".
Press the green button.
Scroll down to "copies"... it probably reads "3".
Set it back to "1" and then press the green arrow button.
Nov 02, 2010 | HP LaserJet 4350 Printer
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
My hp deskjet 3550 is not printing. the green light at the power button keeps on blinking. What is the problem? both ink cartridges are full. there is no paper jam.
May 28, 2010 | HP Color Laserjet 3550 Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
Problem with HP 1320 printer
If the paper size in the word document is set to something other than "letter" example if it is set to legal. Then the lite is lit to let the printer user know it is waiting for him to place a sheet of legal paper in the printer, he does so and then presses the green button to start the print job. You can check this by going to "file-page setup" in word and look for the paper size setting.
Jun 24, 2009 | HP LaserJet 1320 Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Stupid printer
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Sep 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
753 people viewed this question
k24674
