Question about LG Dishwashers
I need a new dishwasher What do you recommend between Kenmore Elite. Quietguard Ultra. Model no. 665.77962K703 versus LG model LDF7920 I get conflicting information- a repairman we know says LG is the better make, needing far fewer repairs than Kenmore in general ( this washer I am thinking of buying was made by whirpool, I was told at the Sears store) But online reports claim LGs need the most repairs. HELP OR... do you have something else to recommend?
  • LG Master
  • 1,369 Answers
Google Consumer Reports Dishwahers. Then try a shopping bot to locate the model on interest that was actually tested. Be sure to read any provisos offered by Consumer Reports. Don't just eye the ratings.
For instance, a Consumer Reports Best Buy is $700 Bosch Ascenta SHX3AR7[5]UC. But you may not want to pay that much or you may want some special feature.
Posted on Jun 16, 2017
    Top Expert:
  • LG Master
  • 42,147 Answers
Kenmore has more calls for help on this site
both whirl[pool and lg have fewer calls
advise you to check out the service repair agents for both and see who is the closest
the simpler the controls the fewer the problems
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Hi jabberr216,
I'm Harvey the Master Plumber.
Your question is: You have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
Sure! Someone must have activated the lock. It is next to either the 'air dry' or 'heated dry' button.
Press and hold that button till the lock light goes out. About 6 seconds. That's it. It turns on the same way.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
SOURCE: Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Posted on Mar 16, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Reset sequence for Sears Kenmore Elite 630.1630?
Unplug for 40 minutes to reset this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore model 665
Power off, check for clogs and if water supply to arm ok. Remove any build ups and reconnect. Good Luck.
Jul 23, 2013 | Dishwashers
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
I need an instruction manual for a new Kenmore Dishwasher
go to kenmore web address its there.adrian,,,,
Jul 13, 2010 | Kenmore Dishwashers
Should the QuietGuard Ultra Sound Insulation on my Kenmore Elite dishwasher become hot enough to allow the barrier under the front panel of the door to melt and break off?
Probably not. Check the insulation and see if it's all there and in place. If the insulation looks fine then the problem may be that your water heater(the one that supplies hot water to your whole house) may be set at too high of a temperature, there should be instructions on how to adjust the thermostat somewhere on the water heater.
Mar 13, 2010 | Dishwashers
Help! I have a kenmore elite ultra wash quietguard delux. the other day my toddler was playing near it so i pressed the button to lock it. Problem is I don't know how to unlock it! Please help me...don't...
Here are the instructions to set and unset the child lock.
Setting the Child Lock:
1. Press the Sensor Dry or Lock pad and hold for
three seconds.
2. An indicator light next to the lock graphic will
illuminate when the controls are locked.
To cancel:
three seconds.
2. The indicator light will go off.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
165 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
