Question about Brother Sewing Machines
Brother 2001 sewing and embroidery machine.
I have a brother 2001 sewing and embroidery machine, that locked up after the warning the safety device was activated. Shutting the machine off did not deactivate the machine it is still frozen. I did clear the thread off that tangled at the loop on top. The shaft on top is movable but stiff. The bobbin area is also stiff. Is there some way to cancel the safety device?
The machine was sewing beautifully til the thread wrapped on the joint just below the upperloop
  • Anonymous Mar 24, 2014
    every time I try to sew I get a message saying "the safety device has been activated"
  • 323 Answers
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
Re brother 770 embroidery machine: Needle shudders/shivers and the safety device light comes on. There is no nesting thread, the needle has been changed, with the flat surface facing back.
Check for proper threading of the machine, Making sure the groove of the needle is facing you as you use the machine. Even the way the bobbin is inserted and spinning in the correct direction, can be the issue.
Manual time...
Cheers,
Embroidery Services
San Diego, CA
Aug 05, 2017 | Brother Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
I need a manual for my older sewing/embroidery machine, Baby Lock Esante ESL.
Yes, you are correct. Baby Lock brands Brother machines under their name with a special agreement between the two companies. Therefore the Brother manual would be helpful.
May 01, 2015 | Brother Sewing Machines
Brother innovis 1200
remove the embroidery unit, change the needle and check again in the bobbin case for tangled thread. Same problem here and this is the way I've fixed it
Aug 04, 2014 | Brother Sewing Machines
Oiling Brother Ultima 2001 sewing/embroidery machine
The only place you can opil an ultim is inside the bobbin case and around the bushings in the front end. Do a search for Anns fix it and you will find more than you will ever need for these machines
Dec 06, 2008 | Sewing Machines
Brother CS-8150
When you say jams up from the under could you please tell me what exactly is jamming up. Is it the bobbin thread jamming? I've had the "safety lock" warning but I need to know exactly what you were doing. OK
Aug 30, 2008 | Brother CS-8150 Computerized Sewing...
Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Apr 30, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
905 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
