Question about Mitsubishi VS-5075 50" Rear Projection Television
Mitsubishi VS-5075 When I plug in the tv I hear a click from a relay on the left hand side of the motherboard (viewing from the tv from the back). The two relays on the (standing vertical sub power board) are not clicking/energizing. The green led on the front of the tv comes on and slowly fades and goes out. No picture or sound?????
  • 2 more comments
  • Mason kid Jun 16, 2008
    I should have said earlier that I have no blown fuses. The regulator that I have ordered is on the Sub Power board STR M6 543. Is this the regulator that you are talking about or is there another one because in your answer you stated regulators?
    I was not able to buy a service manual from you guys, I had to go to Mitsubishi to buy one and I have not received it yet. I'm not positive that, that regulator is bad. It has done alot of work and the pc board is discolor from the heat. I do have 162 volts coming out of the regulator and then goes to a cap. off of that pin of the regulator. When I measure the voltage on one side of the cap. I have the 162 volts and the other side of the cap. I have nothing. Is the cap. bad or the regulator?
    I don't recall the rating but will pull the cap. when I get home and stop at supply house tomorrow and buy one and replace it and see what happens. Its a standard cap. and not an electrolytic. I will let you know the outcome and thanks for the great help.
    J.
    I did pull it from the circuit and tested it with a meter that has a cap. checker and it showed 0.1.
    I going to replace it, like you said its cheap. It probably needs it anyway because of the heated area. Will let you know.
    THANKS!!!!!!!!!
  • Mitsubishi Master
  • 8,617 Answers
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Posted on Jun 16, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Jun 16, 2008
    Theres a couple of regulators, but if that one was defective that would no doubt be the problem, as the regulators run independant of each other by regulatings its own circuit, so the chances of two sepaerate regulators being blown is almost non existant. I just wasnt aware that you had already found a defective regulator.
  • Sonny Berry
    162 volts should charge the capacitor and then the capacitor will discharge when its fully charged there is no way to check the capacitor in circuit unless you have a ESR meter, you can check it out of circuit though. Whats the rating on the capacitor as your probably looking at a 2.00 part if its a standard cap at radio shack its often easier to just replace the capacitor if you dont have an ESR meter.
  • Sonny Berry
    Its probably good then if its a non polarized cap
  • Sonny Berry
    Youre welcome, and yes let me know how you make out.
Pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Sep 21, 2007 | Mitsubishi VS-5075 50" Rear Projection...
The power won't turn on. I hear a
Howdy,
This TV is a 1995 model, I would consider replacement than repair. Sorry, but it will cost about $550 to repair. If I could tell you that it was this little part that only cost $2.00, I would, but these old TV'S it could be anything.
Good Luck, BIG IRISH.
Dec 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
I HAVE SOUND BUT NO PICTURE
Is it a rear projection tv? plasma? or LCD?
Feb 15, 2009 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi YS-5075
yes, this sounds like a fuse blown or open. What model is this a VS or YS?
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Feb 11, 2008 | Mitsubishi VS-6047 60" Rear Projection...
No picture-picture-
Try resoldering the vertical output IC. If you still need a service manual let me know and I will post a link where you can get one.Just post the model number of your set.
Nov 08, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Pip only on screen
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Sep 26, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Televison & Video Logo
235 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
