Question about Whirlpool LER4634J Electric Dryer
I have a whirlpool dryer and it does not start, i tried continuity on the fuse, the start switch, the lid switch and even the thermostats and all are good. i am also gettng good voltage.. i don't know if its the motor or the control timer... can someone help...plz
  • adrian alexis Nov 13, 2010
    how do i check the thermal fuse?? is it from one lead of the fuse to the plug terminal or is it directly across the fuse?
  • 44 Answers
First thing to check is the Thermal fuse, See if its open using a meter
Second, check if you have 120 volts on both sides of the Thermal Fuse
If you do most likely its a bad motor
Posted on Nov 09, 2010
  • Harry Roberts Nov 13, 2010
    Checking thermal fuse, with Ohm meter set meter to ohm's
    Black wire to one prong red to other should read if it don't read its open NO GOOD!!!
  • adrian alexis Nov 17, 2010
    thanks alot i got thru!!!!!
Dryer will not start
The temperature of the air being exhausted is monitored by the cycling thermostat and the thermal fuse mounted on the blower housing. The thermal fuse, which is wired in series with the motor circuit, fails when the cycling thermostat fails to regulate the exhaust air temperature. Failure of the thermal fuse results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
Indicate the exact model number of the dryer for specific troubleshooting and repair advice if you need further assistance and for the exact part numbers.
May 27, 2010 | Whirlpool LER4634J Electric Dryer
No heat whirlpool electric dryer imperial 70 1986 vintage
replace cut off switch fuse at the top of heater box
May 02, 2010 | Whirlpool GGQ8831L Gas Dryer
My whirlpool gas dryer is not starting. the thermal fuse reads fine. I have a 4 wire thermostat next to the fuse. I have continuity between 2 wires. What should I have between the other 2?
Unplug the dryer, and remove one of the wires on the white fuse next to the 4 wire thermostat. If there is continuity on the fuse, then check the door switch. You can do an audible check just by pressing the button in or moving the lever in, which ever you have. Make sure that the motor is not covered with lint as it could have shut off thermally which takes about a half hour or so to reset if it has no air flow. Depending on the model, ( you never stated or the age ) there is another fuse that could be out also that needs checked. The things on this circuit that makes it run are, the wall outlet, the cord, the timer, door switch, internal fuses, the motor and wires, which could be burnt or chewed or simply loose.
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
My Whirlpool Imperial (Accudry) is not receiving power
MOST OF THE TIME IF NOTHING WORKS IT YOUR DOOR SWITCH,OR YOUR MAIN WHITE FUSE ON THE BLOWER BOX,LET ME KNOW-MIKE
Feb 23, 2009 | Whirlpool LEN2000PW Dryer
The dryer will not start
thermostat would not cause it not to run if the white thermal fuse has continuity ck the door switch to be sure lever is not broke also ck breaker after switch timer most logical but unless you know to ck best not just guess could be expensive
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
Electric Dryer No-Start/No-Heat
Try check your timer, and see if you have voltage going to motor. Also check to see if you belt is installed. If broken there is a switch to the belt also. Try check you Door Lid Switch.
Nov 18, 2007 | Roper REX4634KQ Electric Dryer
Whirlpool top loader drier.
Try checking themo fuse on air duck, if blown will kill power to start dryer
Oct 16, 2007 | Dryers
Whirlpool LER4634J Electric Dryer Logo
825 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
