Old copper with paint, cleaned end, fluxed it, tried to tin it and solder will not stick. Tried three times. I was using my plumbers torch so I don't think heat was a problem. I have only run across this problem one other time and ended up replacing the whole pipe.
    Genius:
  • 1,015 Answers
Are you trying to solder on a closed piping system? If so one thing that will cause many problems is any moisture in line. It does not take but a drop or so to vaporize to steam and cause oxidation on pipe or fitting which will cause solder not to stick.If you are working on closed piping try to find valve or faucet somewhere to vent steam. I would clean again and make sure you are using good flux and right solder & try again. Hope this helps. Thanks
Posted on Nov 09, 2010
How do I seal a copper pipe connecter.
The tubing end must be square in order to seat properly in the fixture. The old compression ring may be distorted. The nut may have been cross-threaded at some point. The ultimate solution may be to remove the old fitting and start over with a new one.
May 12, 2014 | Plumbing
I require a method for the useage
Kemtex B916 solder paste?
This = No
"Kemtex B916 Tinning Compound
A 40/60 grade solder paste suitable for sweating together fine tolerance joints and in areas where conventional hand soldering is hard to apply. Also used for tinning motor car bodies prior to the application of bodyfill solder. Can be used for tinning bearing shells for lead based bearing metals."
http://www.cagroup.com.au/Kemtex_Fluxes_and_Tinning_Compounds.asp
Should state Rosin Flux Paste for what you want.
I'll bet the above is acid based.
http://www.radioshack.com/product/index.jsp?productId=2049774
Regards,
joecoolvette
Mar 04, 2013 | Computers & Internet
Need to know easiest technique for soldering stained glass.
Try some of these:
http://www.delphiglass.com/page/knowledgeBaseView?KBItemID=16
http://warnerstainedglass.com/techtips/solder.aspx
http://www.elvesofester.com/soldering.html
Jan 22, 2013 | Welding Tools
Can i install 1989 f-250 cataletic converter with soulder
if you are asking can you solder up a cat converter yes use silver solder metal must be clean and brite for it to stick use propane torch for heat and don't forget the flux allthough the solder cost will outweight the cost of a new converter
Jun 06, 2012 | Cars & Trucks
Cant get soder to hold on copper pipe soder flakes away doesnt stick
make sure joints are clean and sanded,flux-use mapp gas in torch burns hotter then propane,needed for 95/5 solder preheat up and down pipe for a few inches then do joints,keep you torch moving around joints it'llget a silver color then its ready.Don't get to hot or it will burn up flux.ps no water in the line or you'll never get it,cleaning pipe and fitting is most important
Jan 28, 2011 | Nibco Reducing Tee Copper X Copper X...
Having trouble with solder sticking with metal to metal applications
Soldering is intended for soldering alloys together such as copper, silver, gold....solder does not stick well to steel and aluminum...also, you need to use a flux when soldering...this flux cleans the connections of impurities and allows the solder to stick to the metals to be joined...Judging by the iron that you have...it looks like it is mainly used for very small soldering applications where not too much heat is required...If you want to solder larger items(such as soldering to a metal chassis) then I would recommend using a soldering iron or soldering gun with more wattage
Jan 16, 2011 | Weller Bp860mp Battery Powered Soldering...
We can't keep the tip tinned, what do we need to do?
Clean the end of the tip with a smooth file down to bear metal heat it up and retin the end with fresh solder. Are you using multicore solder with resin flux ? some old solder does not have any flux in it.
Jul 29, 2010 | Weller Marksman Iron 40 Watt SP40L
Old Victorian Light fixture needs to be repaired. I think soldering the broken parts together would work, but I've never soldered brass parts (only simple electronic motherboards). Anyone out there that...
to solder brass u just use regular solid solder with a tin of acid flux, but u must use a Small butane fueled pin torch or a large high temperature solder iron to do the heating (this really depends on the size of the material being soldered), the brass must be clean and bright, use steel wool for this these small torches are available from any hardware store, they fuel up with butane cartridges used for refilling cigarette lighters
Jan 18, 2010 | Welding Tools
Can I get replacement batteries for my Norelco 7735X shaver?
I have replaced batteries in several Norelco shavers, typically ending up with better end performance than with the original batteries.
Norelco shavers typically utilize two AA sized NiCad batteries with thin tabs spot welded on each end and the tabs soldered into the circuit board internally.
I have had best success with utilizing Sanyo Eneloop AA batteries, see http://www.google.com/products?q=Sanyo+Eneloop+AA+batteries&hl=en&scoring=p, which are NiMH cells with low self-discharge (i.e. hold their charge for over 6 months) and are free of the memory effects and internal self-shorting problems of NiCad cells.
The key to successfully changing the cells is to leave the original solder tabs on the circuit board and utilize the edge of a single edge razor blade (with great care) rocked back and forth between the metal tab and each of the ends (one at a time) of the original batteries so as to cut the spot weld free from the original batteries while saving the tab.
A single razor blade should do the job, though the blade will now be largely ruined for any further use.
Next carefully flatten the tabs (will be a little deformed by the spot weld break strategy).
Next carefully tin both the tabs and the ends of the new NiMH cells with a small amount of solder.
This tinning is not easy unless you use this strategy: Utilize small drops of "Harris Stay-Clean liquid" soldering flux, a clear (looks like water) zinc chloride liquid flux, e.g. dip a tooth pick into the flux and use just the small droplet of liquid flux which runs off the tooth pick onto the metal. After the flux is where you want the solder, touch a heated soldering iron tip already coated with a tiny amount of rosin core flux for electronic circuit joint soldering to the pre-fluxed area and the metal will easily and rapidly tin with solder.
For the new batteries, use only a tiny droplet of Stay-Clean flux right where you want the solder and touch the costed and heated soldering iron tip to the battery for just 1-2 seconds so as to minimize chances for any damage to the new batteries.
Once happy with the tinning of both the (saved) original batter tabs and the new batteries, hold the new battery in position and briefly touch the soldering iron against the tabs to push it into the battery end and fuse the two areas already tinned with solder.
I does take a little practice to get the above and physical alignments correct. It is helpful, though not mandatory, to use a temperature controlled soldering iron (e.g. set to about 500 F) with a fairly small tip.
Be sure to keep the Harris Stay-Clean flux, even fumes sealed in storage (I usually enclose the Stay-Clean bottle in a clear screw cap larger bottle) because just invisible fumes from this flux on any nearby iron or steel surfaces, over time, will promote rapid rusting. The Stay-Clean is a great product, just be careful with it during handling and storage.
Jan 04, 2010 | Norelco 7735X Electric Shaver
It is not melting the solder. do you have to use flux, like sweating copper? If so, can I use the same kind of flux for this application?
No flux, just make sure the element is heating up enough.
Also make sure the tip is clean. Let it heat up and dab on a wet sponge. You can also lightly file the tip to clean off oxide build up.
If you do this last step. It is critical you Re-tin the tip.
Of course the tip must get hot enough to melt the solder.
If it still does not, I would suspect the batteries.
Hope this helps!
Dec 19, 2009 | Weller BP860MP Dual Heat Battery Powered...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
