Question about Watches
I dont know functions of my new titan 9236ql01 from octane series..can anybody help me out ?
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: I have Titan Octane watch
On some of the analog watches or wristwatches from branch such as Omega and Casio, there is a outer scale bezel that inscribed around the rim and named tachymeter (also known as tachymetre or tacheometer). If you flip through the watch’s user guide or manual, you will not likely to find any explanation or definition on what is tachymeter or how to use the tachymeter functionality. Tachymeter is actually a tool used to compute speed based on travel time over a fixed distance travelled (like one mile or one kilometer). Thus, the tachymeter bezel or dial is a logarithmic scale (actually it’s not, as spacings between the marks on the tachymeter dial are proportional to 1/t where t is the elapsed time) that simplifies the computation of speed of an object, by computing the following function:
Tachymeter Dial = 3600 / Elapsed Time In Seconds
Tachymeter illustration. Depending on on the range of the scale printed on the bezel, tachymetre timer normally works and valid for all elapsed times from about 7.2 seconds to 60 seconds, thus only able to measure speed greater than 60 miles per hour or 60 kilometers per hour.
To use tachymeter, simply start the chronograph or stopwatch when the object measured passing the starting line. When the object reaches the next mile or kilometer marker, stop the chronograph or stopwatch. The point on the tachymeter scale that adjacent to the second hand of the watch indicating the speed (in miles per hour or kilometers per hour) of object traveling between the two points.
For example, we want to measure the average speed of a vehicle is moving. Start the chronometer or stopwatch function when the car passes the starting line, and stop the timer after the vehicle traveled exactly 1 mile or 1 kilometer. Then look at where the chronometer hand (the second hand of the watch) is pointing to, and get the reading or value of the corresponding number at the tachymeter bezel or dial. Let’s say the stopwatch stop at 3 o’clock position, meaning 15 seconds had elapsed for the car to travel 1 mile or 1 kilometer. At 3 o’clock position, the tachymetre value shows that number of 240, which means the average speed of the vehicle was 240 mph or km/h.
Due to the limitation and constraint on the tachymeter scale mentioned above which makes tachymetre measurements works and valid only for certain range of speed, so in order to calculate and measure slower speeds or higher speed, user can decrease or increase the unit of measurement (e.g. change to half-miles or half-kilometers, or ten miles or ten kilometres). However, simple calculation is needed in order to get the correct average speed by using this technique. It’s also true if the length of the distance does not exceed a unit of mile or kilometer, or other unit which the speed will be based on.
For example, if we want to measure how fast the 200m athlete is running. Start the chronometer when the race starts, and stop the stopwatch when athlete crosses the finishing line. Let’s say the athlete used 20 seconds to finish 200m running, so according to tachymeter, the speed of the athlete is 180 km/h. However, the athlete only ran one fifth (1/5) of a kilometer, so we should divide 180 with 5 or 1/5 of 180, which mean the actual speed of the runner is 36 km per hour.
The above example can be used for object or thing that moving too slowly too, as when the object travels 1 mile or 1 kilometer, the duration would have exceed 60 seconds, the maximum limit of tachymeter. So the possible workaround is to measure the time taken for the object to move a shorter distance (such as 100m) and divide the tachymeter value with 10 (as 100m is 1/10 of a kilometer).
What if the object travels too fast, such as a rocket or plane. In this case, user can increase the units of the distance covered by the object to measure a longer period of time so that the duration is greater than at least 7.2 seconds (typically the lower limit). We can measure the time taken by the object to cover 10 miles, let’s say it took 30 seconds, so the tachymeter will tell us the the speed is 120 miles per hour. However, 10 miles have been traveled, so that actual speed is 120 times 10, which is 1200 mph.
I try to find other functions descriptions to send in short time. Good luck.
Posted on Aug 25, 2010
Does anybody know the correct part number or provide a link where I can purchase a Bezel ratchet spring for Tag Heuer WAC1113.BA0850 Formula 1?
Hi thank you for answers but it doesn't help me given I already have the bezel off. What I actually need is the actual size of the Spring? I know they are available to buy on eBay and watches.com.uk but to not even bother to respond to you inquiries for some reason?
Does anybody know the correct size of the "friction/ ratchet bezel spring" on a Tag Heuer WAC1113.ba0850 model 2004 - 2007 ?
May 11, 2016 | Tag Heuer Watches
Manual guide
name and number of watch please ?
Jul 07, 2013 | Watches
I Have a Ricoh Watch. I believe it to be the Ricoh Automatic Watch released as a pack when they released their first automatic camera (a camera specialist friend gave it to me as a gift). However, I cant...
I dont exactly understand what your problem is with your watch, but if you just do a GOOGLE image search using RICOH WATCH in the search., it will pull up a ton of images and you can find your watch that way.
I dont know if that is the answer to your question, but it will work.
Best regards.
Aug 23, 2010 | Watches
I want to know the price of the titan watch model no. 1225BAA
mcdevito75 here, I did a fast web search and couldn"t find this model number, Titan watch is in India and I did find their website at www.titanworld.com type this into search from your home page for all info.
Aug 11, 2010 | Watches
The problem is that i simply dont have the users manual and dont understand how to manipulate my watch
mcdevioto75 here, I'll try to help, 1 of the buttons should say mode, if no button look for a in-dent naer the other buttons and push that in, or press the mode button and see the dial blinking, press set to cahnge and adjust each function, Hour, Minute etc. after each function is set press mode to mave to the next function when done with your functions, press mode to return to a staedy dial.
Jun 21, 2010 | Watches
I don't know how to switch the alarm function off. Help, please! I've lost my instruction manual and in fact I don't know how to use any of the functions!
You can get instructions from their web site (www.adidas.com/campaigns/watches_fw07/content/index.asp?)
Click on "instruction manuals" in the menu on the left, choose your country.
You will be presented with a series of generic instructions from which you should choose the ones that suit your watch.
Mar 22, 2010 | Adidas Medium Watch Candy ADH1570 - WW
Not again . . .
Pushing all the buttons at the same time you resets the digital functions. You'll have to reset the time and date, but it will all work again. I don't know why the watch freezes up, but pushing all the buttons at least resets it. I like my watch and this quirk is an annoyance, but it's livable after finding this solution.
Jul 10, 2007 | Timex Expedition® Outdoor Casual...
Watches Logo
62 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
