Question about Sony Cyber-shot DSC-T20 Digital Camera
Why sony camera vibrates - Sony Cyber-shot DSC-T20 Digital Camera
  • 87 Answers
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Posted on Dec 20, 2010
IS IT NORMAL FOR A CAMERA TO VIBRATE EVERT TIME I USE IT?mY SONY CAMERA VIBRATE IF I USE IT , BUT THERE TIMES ALSO IT DONT.
To stop your camera from vibrating, you have to disable the vibrate function in the system setting. If the vibrate function is already disabled and the problem still occurs, you have to refer your camera to a certified technician there is a problem in the command center of the camera.
Nov 02, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Camera vibrates
better get it to a Sony store.
my cousins also suffered from the same problem.
Apr 30, 2010 | Sony Cyber-shot DSC-T10 Digital Camera
Sony dsc-t70 camara vibrates when turn on
it's actually a failure with the lens mechanism, I just experienced the same situation....Sony has another T20 that they had the same situation with and they offered to fix the cameras until July 2011..currently checking if Sony will fix this defect in this T70
what you are experiencing probably is best described by this article:
www.sonyinsider.com/.../dsc-t20-cyber-shot-camera-vibration/
Oct 25, 2009 | Sony DSC-T70 Digital Camera
The camera wil vibrate much like if your cell
Vibration in this model is problem with lens assembly.
Qualified camera tech can fix it either by repairing lens mechanism or replacing it.
Aug 12, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
DSC-T20 Sony Cyber Shot Camera that vibrates like a cell pohne. The vibration does not allow for a good picture it all. Could it that the anti vibration system of the camera goes into a full mode trying to...
Hi!
The problem you have is a faulty image stabilizer. It's a well known problem in these cameras. It's a hardware fault and I'm afraid you won't be able to fix it yourself. Usualy it requires the lens unit to be replaced. You should contact your local Sony service center or me at toms.safranovs@gmail.com - I give the best prices. ;)
I work in a Sony service center.
Hope this helps!
Tom
Jul 29, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Alpha A100 shakes when I turn it on
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
May 14, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony dsc t20
I found the following shortly after posting my similar problem. It looks like Sony will fix the camera:
http://www.photographyblog.com/news/sony_cyber_shot_dsc_t20_problem/
Oct 17, 2008 | Sony Cybershot DSC-T200 Digital Camera
Vibration when using the Sony Cyber-Shot dsc-t20
Well, it seems that this is either a manufacturing defect or a defective/sub-standard part being used in the product. It would do Sony well to address this problem immediately so that all of us Sony lovers would continue to believe in their products. If this can be solved via a firmware upgrade then I hope Sony can guide us through it.
Feb 22, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot  DSC-T20 Digital Camera Logo
53 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
