Question about Casio Cassiopeia Fiva MPC-205E PC Notebook
Restore system I cant start the operate system from c: , how can I boot the system, I try from usb but no is possible. what device do i need to restart the system.
  • 42 Answers
Insert a bootable disk and then restart your system... if u have usb boot device means change the bios settings to usb priority mode...
Posted on Jun 17, 2008
Work recovery system, it wants to access recovery options, but i cant remember password
reboot laptop and keep tapping the f8 key while its booting.
you will get an options screen, select ''boot into safe mode''.
it should then boot up in safe mode, once on desktop go to start menu>>all programmes>>and look for the acer recovery tools...ity will be their as all acers have these tools.
in the recovery tool, you will have the following options.
factory restore computer = thios will erase all your files from the hard drive and reinstall windows again, once done it will be the same as when you first bought it and took it out of the box.
or..restore windows files and settings only = this restores the windows files system so as to fix the errors that are causing problems, none of your personal files will be erased or lost and will still be on the computer once the operation completes.
i would go with the first option and do a factory reset. If you have personal files you want to keep, then when booted up into safe mode yhou can copy those files to a usb thumb drive or a CD or whatever. Once you have your files saved, perform the factory restore instalation.
Or you could just boot into safe mode, and if you get onto desktop, goto start menu>>all programmes>>>accesories>>system tools>> back up and recovery. From their, select ''system restore''...it will show a list of restore points with dates next to them. Their will also be a box unticked that says ''show more restore points''. tick that box so all restore dates and points are showing.
Then select a restore point and date about 5 to 7 days before the problem occured.
so if the problem happend on say the 7th november.....restore it back top around the 30th october.
this will just undo any system changes that are causing errors and get your pc working again without affecting any of your personal files.
if all the above fail, you will have to reinstall windows yourself, just download the iso from microsoft website
download the 'windows 7 usb tool' from microsoft website.
insert a USB thumbdrive at least 4GB in size.
run the windows usb tool and follow the on screen instructions which will then
load the windows downloaded file onto your usb drive.
once done, reboot pc and hit f12 (or whatever key it is for your model to enter the boot options menu - a quick search on google will tell you the key for boot menu if f12 or esc key do not work).
once in boot options menu..select your usb device to boot from and press enter.
windows will then install on your laptop.
once on desktop, goto start menu and eright click on ''computer''.
select 'properties'
then select 'device manager....and cxheck to see what drivers may be missing.
once you see what drivers are missing...goto acer support.cm (you may have to use another computer to do this if your ethernet or wi fi driver is missing and you cant access the internet.
once on acer website, selecter the drivers and manuals tab......it will then ask you to input your computer model number, brand, operating system.....then it will give you a list of all the drivers for your machine...now download the ones you need, then install them by opening the file and double clicking the ''set up .exe' file.
once all drivers are in reboot nachine and then wait for wqindows update to kick in and apply the neccesary updates.
Nov 07, 2014 | Acer 4220-2346 Notebook
Acer aspire boot
If you did system recovery, besides this problem occur before the PC was too slow or restarted .....
Possibly need to replace the hard drive.
Test you ran an operating system from a USB can try SLAX.
If you have a desktop PC, put the hard drive used and subjected a scandisk.
Oct 25, 2013 | Computers & Internet
"For Atheros PCIE Ethernet Controller v2.0.2.3(05/18/10) Check Cable Connection!"
The operating system is looking for a boot device
Make sure there are no discs in the drives cd/dvd and usb
make sure the bios is set to boot from your hard drive or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem.
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Nov 25, 2012 | Computers & Internet
Blue screen of death
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Nov 12, 2012 | Microsoft Windows 7 Ultimate for PC
EP-3VSA2 - based on PC brakes operation with BSoD randomly: BSoD may occurs sometimes during Windows startup and sometimes seconds after an hour or two of operation. What is the matter?
Remove all USB attached devices.
Win 7 - Start > Start > Search type System Restore.
Oct 11, 2012 | Computers & Internet
Everytime i boot my Toshiba Satellite L305D i get a message on a the black screen before windows startup saying "windows has encountered a problem communicating with a device connected to your...
If you have external USB and/or CD disconnect them and try again. Otherwise it could be a fault hard rive - try to boot from an emergency CD (hopefully you created one when you installed Windows).
May 11, 2011 | Computers & Internet
How do you wipe a computer with windows xp, without the cd or a floppy. there has to be a way to use a usb. (computer wont boot passed welcome screen). don't need to save xp either.
If your system supports it you can go into your Bios (right when computer starts booting up you press (usually "Delete" key) to enter Bios setup.
In the Bios you go to Boot devices, any devices set up for booting will show in a list in numerical order, this order is the order your system gives preference for booting. Most times you will see your hard drive and your cd drive already there. Select the first one and open the pop up menu for it (on the right side of the screen it should tell you what key to hit to change the value), if your USB device is there then select it to be your first boot device. Then hit the key for that 'Exits and Saves Changes' (usually F10). This exits Bios and starts your system booting up again.
Before you boot up though you need to have your memory stick set up with either Windows Install files (i.e. burning the windows install disc to your usb device) or format your USB device to be a boot disc (this will only then allow you to boot to a DOS prompt though and you would still need the Windows files)
Feb 19, 2011 | Microsoft Windows XP Home Edition
Can someone please help me.I cnt get my laptop to boot.When it starts it goes directly to a screen that says start up repair.then it says it cant fix the problem and turns off
It seems the boot program on your hard disk has messed up. Did you try to boot with a CD come with the laptop and do a repair? Or you can restore it to the factory default by pressing a key during booting up. It should be on the manual about the steps of booting up for factory default system restore. I would recommended you to boot with a bootable flash drive or a CD to back up your files. Those bootable flash drive or CD can be bought or made with some operating system. (Most of time Linux). Here is some links to show you how to make USB bootable drives.
http://articles.techrepublic.com.com/5100-10878_11-5490289.html
http://www.bootdisk.com/pendrive.htm
You will need to change BIOS settings to boot with USB device first, there might be several USB device there you can choose the non mass storage ones if not sure which one to boot with first. But anyway it will try all of them so put your hard disk to the bottom. After booting and you can access the files on your hard disk, you will be able to move them to your USB device. Then restore it to factory default. If it still halts, then maybe the hard disk is not working properly, I will check it for you with more information like the beeps or other symptoms and the detailed model number of your computer. Or you may contact the reseller or manufacturer.
Nov 14, 2010 | Computers & Internet
The problem is my emachine laptop does not want to start up it is asking me a boot decives wch l dont have, the model for my emachines is E525, where can l get the boot device?
It is asking you for a bootable drive or device.
Your windows OS is your main bootable device, if it is not booting, you must have a error in your windows installation.
Other bootable devices can be your Windows CD, or a USB drive with some bootable media on it.
Try tapping F8 when you turn your PC on, it will give you the option to boot into safe mode, or may also give you repair / restore options.
Try booting into safe mode and do a system restore
Sep 30, 2010 | Computers & Internet
I want to reset the settings on my hp mini to its factory settings.
Hello try to download the files on another computer running a Windows operating system and restore your
device, follow these steps:
1. From your computer, go to http://www.hpmini.com and download the
HP MIE Restore Image Creator utility and the HP Mini MIE recovery image.
2. Insert a USB flash drive into a USB port on the computer.
3. Launch the HP MIE Restore Image Creator utility from the Start menu.
4. Click the Browse button and select the HP Mini MIE recovery image.
– or –
Select HP Netbook Recovery Image to download the latest HP Mini MIE recovery image from
http://www.hpmini.com.
5. Click Start.
6. When the process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP MINI.
8. Change the boot order by turning on or restarting the device, and then pressing f9 while the “F9 =
Change Boot Device Order” message is displayed in the lower-left corner of the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Press enter again to begin restoring the device.
11. Follow the on-screen instructions to install the operating system and programs.
12. After the operating system and programs are installed, remove the USB flash drive(the device will automatically restart)
13. Restore your personal files and you are done
Good luck
Jan 20, 2010 | HP Computers & Internet
Casio Cassiopeia Fiva MPC-205E PC Notebook Logo
114 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
