Question about Samsung HL-T5687S Television
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Posted on Nov 22, 2010
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Tv is on but no picture no sound
LED power supply board behind access panel on side of TV back can cause this problem
Nov 27, 2013 | Samsung HL-T5687S Television
Hi. I have a two-year old 56 inch HL-T5687S -- I have sound and picture, but then picture turns black and sound keeps playing . I turn off TV, wait a bit, and TV pic comes back on... then black after 2-15...
These problems are the cause by those 2 long LCD inverter boards are dying.These 2 long LCD inverter boards,help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay,com to buy those 2 refurbishes long LCD inverter boards for the replacement.Replaced these 2 long LCD inverter boards,should solved ur problems,u having.
Sep 10, 2010 | Samsung HL-T5687S Television
I have a HL-T5687S DLP TV. Since yesterday, my tv
right side push button stick ...check and open stick button
Nov 07, 2009 | Samsung HL-T5687S Television
How to reset malfunction code C0500 of a imagistic im2020 copier
On the side of the control panel, there is a little hole, use a paper clip unbent to press the switch inside hole. The touch screen will restart. watch the left hand side 2/3 up, a little dot will appear, when it does, press 3. The login in is all zeroes. press trouble reset and then turn off and on using the switch at the left side, lower back edge of machine.
Nov 06, 2009 | Office Equipment & Supplies
Little dots on right side of margin (Brother HL-5040)
I would have guessed the trouble shooting steps you first performed. It could still be a bad imaging drum. Or a fuser. Not sure if this model has a replaceable fuser or not.
Jul 08, 2009 | Brother HL 5040 Laser Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Can smears when priting be fixed
Have you tried cleaning the corona wire on the drum unit (the blue slider bit)?
Replace the drum unit (assuming you have already replaced the toner cart?)
To check the remaining drum life press the go button 3 times. A report should print out with the info on. Even though you may have some remaining life, the drum can fail early.
If the dots/marks are repeating about 3 times down the page it is almost certainly the drum unit that has the problem.
Apr 16, 2009 | Brother HL 5250DN Laser Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Samsung HL-T5687S Television Logo
320 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
