Question about Timex 1440 Nylon watch
How do i change the time on the timex 1440 i change it once before but i through the derections away and now evertime i try too change it again it just goes to stop watch so i think i must be doing something wrong
  • 794 Answers
Hi jazzz78d,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 15, 2011
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
Timex 1440 Sports Radio Time and CDT Instaructions
just change the time from the menu...unless we're missing something here
Mar 09, 2008 | Timex 1440 Prizefighter 53032 Sports...
How do you set the time/date, etc.? This watch is a 1440 sports with plastic wrist band.
press and hold mode button until the digits flash (it is to set the alarm) then press again once the mode button, this time the time flash to be set, the digit that flash is changeable, the lower right button is for adjusting, the upper right button is to choose what you are going to change, while pressing the upper right button you will see all you have to change the time , the date, the day of the week. if your done with all of this. press mode button once, i hope i had been helped you.
Sep 06, 2011 | Timex 1440 Nylon watch
Trying to set time on Timex 1440 sport with mode button top left, start/stop upper right,adjust bottom right,indiglo bottom left..no instructions match or work.
press and hold the mode button until the digits blinks then press it again once, (digit that are blinking is changeable) use the "start/stop button to choose what will you change and adjust buttton to adjust it. if your done, press the mode button again once.
Aug 10, 2011 | Timex Watches
How do i get the timex 1440 sports watch military time to change the hour and minutes wont change
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Jul 15, 2010 | Timex 1440 Sports Aggressor 56014 Wrist...
How do you change the time on a Timex 1440/
manual download"
Mar 06, 2010 | Timex 1440 watch
Trying to set the time on a timex 1440 that someone gave me second hand. I am in Lima Peru so the automatic time change doesn't work. I don't kow what all the little icons at the top stand for either.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 17, 2010 | Timex 1440 watch
I have a timex 1440 sports watch with only 4 buttons. I cannot change the time. I have tried many combo's of pushing them and I can't change the time. What do I do?
I assume that you do not have the instructions, so you need to download them from the Timex web site.
Go to "timex.com", at the bottom of the screen is a tab "Product instruction ...." select this and choose from the selection given.
Jan 06, 2010 | Timex 1440 watch
I don't know how to set my timex 1440 sports watch
1. it is easy all you have to do is hit mode
2.then you will se all zeros
3.hit mode again
4.then you will see a number blinking then press start/stop button and it will change to the next number
5.then just set it to your clock time and your done!!!!!!
hope this will help you
Dec 26, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Timex 1440 Nylon watch Logo
65 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
