Wireless router i have a philips cka5720 wireless router which i am trying to setup the problem is my laptop will not conect to the router during the set up
  • kalpesh jain
    kalpesh jain May 11, 2010
    its showing the signal or not which type of connection you are using and one more thing you do properly configuration of the router
    President:
  • 169 Answers
During setup you must have a RJ45 ethernet cable plugged, one end on your router and the other on the laptop.
Make sure on your laptop, that the Local Area Network Connection is "Enabled".
If it is "Disabled" Just double click on the icon to "Enable" it then try your Setup process again.
This should work.
Regards,
Abdul Qayyum
Posted on Jun 20, 2008
Okay, i have been attempting to set up my HP officejet 4500 G510m for a wireless network for like an hour. i have it connected to a d-link 300 N wireless router via ethernet. however my laptop which is...
have you tried to go to the setup of the printer? try connect first the printer directly to your laptop and configure the network settings before going wifi. tnx
Aug 18, 2011 | Office Equipment & Supplies
My wireless connection , says "Limited or no conectivity" I have excellent signal strength. This occured when i plugged in a second lap top with cable. Now only port 2 works and wireless is restricted. I...
Usually this is caused because the security settings on the laptop or PC do not match what is setup on the wireless router. Login to the wireless router and look at what is setup for security, WPA, WPA_PSK, etc, also the passphrase, it is case sensitive. The setup on your laptop must match.
Jun 22, 2010 | D-Link DIR-655 Wireless Router
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I want to setup a wireless connection
To set up wireless connection, first you will need to access the router set up. yhen change the wireless settings on the computer.
Secure the wireless network and then try to connect to the wireless network ?
Click Here for step by step info
Nov 22, 2009 | NetGear WGR614 Router
Ihad internet conection how would i connect d link 802.11 wireless router to make my laptop wireless
connect your modem to the router and go into the setup of the router and set up the wireless settings for your wireless network
Oct 05, 2009 | D-Link 802.11g Wireless Router WBR-1310...
109 INTERNAL ERROR
try to login to the router, plug the router in directly into the laptop and go to 192.168.1.1 and login and see that the settings are setup correctly and also try to set the wireless with all things off with the settings set to DHCP
Jul 14, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Problem with Toshiba wireless conection
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Feb 20, 2009 | Toshiba Satellite M45-S331 Notebook
Cannot conect to internet
The router does not ask for a password unless you log into the setup page @ 192.168.2.1
So it must be the software that is controlling the wireless adapter ont that laptop. I would uninstall/reinstall the software for the wireless card. And then set it so that windows controls the wireless conne
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
ction
Nov 22, 2008 | Belkin (F5D8231-4) Wireless Router...
Wired vs wireless
Yes. Wired will be faster and setup is the same. You turn off the wireless on the laptop, and plug in the ethernet cable. The settings are probably defaulted to obtain an IP address automaticlly and that should work.
The wirelss will continue to work as it did before for the other machines.
Carl
Aug 29, 2008 | Microsoft Broadband Networking MN-500...
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
