I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means? can I clean this error by myself? could you please guide me? I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means? can I clean this error by myself? could you please guide me?
You can't post conmments that contain an email address.
u 61 means-displays when a malfunction has occurred,playback or copy.this is displayed when the unit is in the recovery process to return to normal operation,it is not broken.once the display disappears you can use the unit again.
That error means: There was a power failure or the AC plug was disconnected while the
unit was on. The unit is carrying out its recovery process. This
process restores the unit to normal operation. The unit is not broken.
Wait until the message disappears.
I suggest you unplug all the cords o the unit and after 2hrs replug and see if the error is gone.
The unit is carrying out the recovery process without a disc in the tray. The unit detected an error while recording or playing without a disc in the tray. The recovery process restores the unit to normal operation. Have the unit power cord unplug for about 5 minutes, then reconnect. If issue still exist have unit service.
From User guide: U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ [email protected]
Thanks !
you have a jammed tray button, its really easy to fix, just take it down to a local dvd repair guy. I am one! and I quote a problem like this as about $15-20 and about 30min of your time :)
good luck!
p.s.
if he/she charges more just take it to someone else!!!
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
