Question about ASUS G50V-A1 Notebook
ASUS G50V (Windows Vista) - recent problem at startup. I have a couple toolbars at the bottom of the screen for my Word folders. These toolbars are opening at startup (as if I clicked the little >>icon. If I right click on the screen, another one opens and I can't do anything else. CTR-Alt-Del seems to stop this from happening, and I can open my browser as usual. One other thing I've noticed since this problem started is that when I power up the computer, I hear a faint clicking sound a few times (like an electrical short). Ran a spyware check and came up clean, also did a Disk Cleanup.
    Master:
  • ASUS Master
  • 247 Answers
Call to Our Technical Support Number 1-800-204-4427 for Window Vista and Get Instant Resolution of Your Query.
Posted on Apr 15, 2017
patemi
  • 366 Answers
SOURCE: White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Posted on Dec 30, 2008
mahhek
  • 662 Answers
SOURCE: trying to boot up a toshiba laptop and getting
SOLUTION 1
- Get your Vista installation DVD and pop it into your drive.
- Then restart your computer.
- Set your computer to boot from DVD or CD in your BIOS.
Vista will ask you for language and keyboard layout information, after which you will be asked if you want to re-install Vista or repair your existing installation.
Select Repair. After which Vista's System Recovery Tool will start.
Select Startup Repair and let Vista do its thing! That really is all there is to it!
If that doesn't work try this:
SOLUTION 2
If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
- Press a key when you are prompted.
- Select a language, a time, a currency, and a keyboard or another input method, and then click Next
- Click Repair your computer
- Click the operating system that you want to repair, and then click Next
- In the System Recovery Options dialog box, click Command Prompt
- Type bootrec /rebuildbcd and then press ENTER
• If Bootrec runs successfully, it will present you with the installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully.
• If Bootrec cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order shown below: (Remember to press ENTER after each command)
bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
- Restart the computer.
Posted on Sep 24, 2009
  • 161 Answers
SOURCE: Screen flickers
i know asus have 2 year warranty ,u can take to warranty
Posted on Jan 16, 2010
SOURCE: what does ' a disk read error occurred press ctr
my computer says you need to upgrade ur system wahat does this means HELP ME?
Posted on Mar 29, 2010
  • 10 Answers
SOURCE: cant start netbook acer zg8
usually means hard drive is bad if there's any data on this computer u HAVE to have leave it off and take it to a com repair shop or plug the hard drive in to another pc that works and see if you can copy any data off. youll probably need a ide to usb, sata to usb or an extra sata cable/connector on the mobo and power connection
Posted on Apr 08, 2010
Can I replace a G50V US keyboard with a UK keyboard
Hi Alan
this should be possible, you will need to change the language in the control panel for all of the symbols to be in the correct places. Hope this helps.
Feb 19, 2013 | ASUS G50V-A2 15.4IN Notebook
Tip
How to make your volume icon show up on your toolbar for Windows Vista
If your volume icon on the bottom right side of your screen is missing for some reason and you can't seem to get it to re-appear then this tutorial will help you get it back!<br /><br />This tip is for Windows Vista-<br /><br />1) Open your start menu and search for Regedit.<br />2) Open the Registry Editor<br />3) On the left side scroll up to the top<br />4) Open the folder HKEY_CURRENT_USER &gt; Software &gt; Classes &gt; Local Settings &gt; Software &gt; Microsoft &gt; Windows &gt; Current Version <br />5) Now if there is already a folder in Current Version you should right click and delete it. Now right click the folder Current Version and choose to make a new folder. Name the folder "TrayNotify" (The text is case sensitive so make sure to enter it exactly how I typed it.<br />6) Now exit out of the registry editor and press CTRL+ALT+DELETE<br />7) Open your task manager and go to the processes.<br />8) Find explorer.exe and right click and end the process.<br />9) Parts of your screen will disappear, if they don't re-appear then choose File and Run.<br />10) In run type in explorer.exe<br />11) Now your volume icon should be back!<br /><br />I hope this helped!<br /><br />
on May 17, 2011 | Microsoft Windows Vista Home Basic for PC
Asus computer freezing up
Windows vista is a large operational system that caused the very complaints that people were talking about and that is why window 7 came in because it is lighter and faster and takes less resources. But to address your problem sub out the ram memory one at a time to see if there is a difference, quite often reseating the ram will sometimes fix the problem.
Jun 04, 2012 | ASUS Computers & Internet
How to turn on built in webcam on asus g50v
Try installing the WEBcam driver.
You can download the WEBcam and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 21, 2012 | ASUS G50V-A1 Notebook
Hi, is there any way i can recieve a free cd or direct download of a recovery/reboot disc for my Asus G50v (Windows Vista Home Premium) laptop? i want to have it back to factory settings like when i first...
Hello.. It is Very Possible that you have what is called a 'RECOVERY PARTITION', which has the rerecovery disk information installed on your Hard Drive. This eliminates having to use a CD. To access the Recovery Partition do the following: 1) Press F9 during Bootup. 2) Press [Enter] to Select Windows Setup [EMS Enabled] 3) Read the 'ASUS Preload Wizard' screen and click NEXT. 4) Select Partition Option and click NEXT. 5) FOLLOW INSTRUCTIONS TO COMPLETE RECOVERY PROCESS. ***Visit www.asus.com for updated Drivers and Utilities***
GREAT LUCK TO YOU!!!
Aug 09, 2011 | ASUS G50V-A1 Notebook
I wish to uninstall My Start toolbar and get rid of it a my homepage. Thank you.
To disable all unwanted start up items in vista, please follow the mentioned steps-
1. Click on the Vista start icon in the bottom left corner of your screen.
windows_start_logo.gif 2. Type MSCONFIG in the search box and then either press enter on your keyboard or double-click on the MSCONFIG program that appears in the search results.
Or, if you're already logged into Vista as an administrator, you may see a box asking you if you would like to continue.
4. Once you have successfully passed through Microsoft's User Account Control roadblock, Vista will launch Microsoft's System Configuration Utility. Click on the Startup tab.
4. This takes you to a page with a list of "startup items." Startup items are programs that are automatically loaded every time you turn on your computer. Some startup programs are absolutely necessary, others are simply a waste of RAM.
Please uncheck the ones that you don't want.
2- To change home page in Internet Explorer, please follow below mentioned steps-
2. Type inetcpl.cpl in search and hit Enter key.
3. Click on tools tab and select Internet options.
4. Click on General tab and select use blank under home page.
5. Click on apply and then OK.
The home page would be blank.
Mar 21, 2010 | Microsoft Windows? Vista Home Premium...
I get the message c:PROGRA~1MYWEBS`1ar.binM3PLUGIN.DLL when I start up Vista
That file belongs to the My Websearch toolbar, which is malware. If you have recently cleaned up your computer to remove malware, then a reference was left in Startup. If you have *not* recently cleaned up your computer, you need to do so.
I would suggest using Search and Destroy which you can get and use for free
http://download.cnet.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html
Feb 01, 2010 | Microsoft Windows Vista Ultimate Edition
Screen flickers
Jan 16, 2010 | ASUS G50V-A1 Notebook
Soundman
If you have the 32-bit version of Windows XP install click this lick to install the driver from asus.
http://dlsvr.asus.com/pub/ASUS/misc/audio/alc655/32b366.zip
If you are running Windows 64-bit edition (most poeple are not)click on the link below to download the driver from asus.
http://dlsvr.asus.com/pub/ASUS/mb/socket775/P5S800-VM/Realtek_AC97_64(WHQL).zip
I looked for drivers for Windows Vista, I'm assuming Vista autodetects the hardware.
Feb 08, 2009 | ASUS P5S800-VM Motherboard
ASUS G50V-A1 Notebook Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
