Question about ASUS P750 Smartphone
How/where to buy housing for asus p750 - ASUS P750 Smartphone
How can i make call with Samsung P750
There are number of voice over ip apps that may work for you. SKYPE comes to mind. Jeep in mind, different apps, support different devices
Mar 03, 2013 | ASUS P750 Smartphone
I want to change chinies to english language in my asus p750
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
if you need, and you don't have copy of the manual, let me know
Sep 13, 2012 | ASUS P750 Smartphone
Asus P750 unable to send and receive sms? And incoming and outgoing call cant hear the answer voice?
I encountered the problem of unable to receive and send sms. I do a new flash of rom and the problem resolved.
This situation has occured twice since I used p750.
Sep 09, 2010 | ASUS P750 Smartphone
I have Asus P750 phone, and i tried up to connect to the interenet by using ma phone's modem, but modem is not detecting with my PC, so i need to download PC suite for dat, what can i do for that?
You need to install Active-sync which come along when you purchased the pda, if you do not have one, you can download from the net. After that, connect your phone to pc and launch the Internet sharing from phone,
Aug 16, 2010 | ASUS P750 Smartphone
How to change language setting in ASUS P750
Tap 'Start > Settings' (it is represented by a gray gear in front of an yellow folder. It should be the second item, from the bottom to the top, the closest one to the question mark (which stands for Help). Tap the second tab (standing for 'System') and search for an icon representing the Earth (standing for 'Regional Settings'). Tap over it and choose the language that better suits your needs, in the dropdown menu. Tap OK to save and quit.
This procedure won't change the entire ROM to the language you want, of course, but will allow you to better understand what is going on with your device, from now on.
Hope you are able to sort your problems out.
Regards,
Carlos
Jul 23, 2010 | ASUS P750 Smartphone
ASUS P750 PDA Phone speaker not working
or try to insert and pull out HF jack several times. It worked for me.
Jan 08, 2010 | ASUS Computers & Internet
Instructions to replace LCD Display For Asus P750
Absolutely no problem. I had done it already with succes. Open the phone, replace and you are done! You cand download "P750 maintence manual" from internet, just google it. But open the housing carefully with no force, it can crack easily.
Sep 27, 2009 | ASUS P750 Smartphone
ASUS P750
dude buy a new phone
Aug 31, 2009 | ASUS P750 Smartphone
How to play song asus p750 in bluetooth handset
Hi
Just connect proper with your P750 thats it
Im enjoying with my
Harry
May 30, 2009 | ASUS Mypal A730W Windows Mobile 2003
ASUS P750 Smartphone Logo
181 people viewed this question
Top ASUS Cell Phones Experts
270rexton
270rexton
Kolbrun...
Andrew Taylor
Andrew Taylor
Are you an ASUS Cell Phone Expert? Answer questions, earn points and help others
