Question about Acer Aspire 4730-4947 Notebook
DVD Drive is broken (mechanical brokage + defocusing, cannot read DVD), is it possible to replace DVD-Rom for a new, more powerfull one?
Yes, you can replace it. Remove the old one and make sure that you have an IDE or SATA connector and get the same connection.
Get an HL-DS or an TSST drive. Avoid Sony Nec Optiarc.
When you have the new drive, remove the front bezel from the old drive and install it on the new one to match your PC.
Posted on Nov 09, 2010
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Regards,
fossildude
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
How can i burn aduio or mp3 disk on the DVD-Rom because my CD-R drive is broken.
Sorry but a DVD ROM or CD ROM can't burn thus called ROM (Read Only Memory) Must be a DVD/RW or CD/RW (Re Writable)
Oct 10, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Dvd-rom drive doesn't open
Sounds like the drive eject motor is broken, maybe time/easier to by a new DVD Burner?
Mar 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
COMPAQ PRESARIO DVD ROM NOT READING ANY CD AND DVD PLS HELP
It sounds like you need to replace the DVD Rom itself.
They do go bad without warning.
A DVD Rom is not that expensive and should take about 5 min to replace rather easy job.
Happy Holidays
Dec 19, 2008 | Compaq Presario Notebook
Dvd rom does not operate
you need to go to hp.com website, they will able to tell you where you can get a replacement.
it is easier to order it from hp.com
try to clean the lens with a DVD claner first, and try to clean the inside of the DVD drive.by using some compress air.
Oct 24, 2008 | Compaq Presario X1000 Notebook
Wont eject
Hi, If there is a disc in the drive it's possible that it has become jammed and therefore will not allow the door to open. If you get a large paperclip and bend out one side you will find there is a little hole in the front of the drive. Insert the straightened end of the paperclip carefully into the hole until you feel resistance. Gently but firmly you will need to apply an amount of force and the door will pop open. Remove the disc and restart the computer, hopefully the drive will now respond as required.
If not then possibly the door mechanism band/spring has become too loose or broken. At least these days CD/DVD drive are not too expensive to replace.
Let me know how you go,
SeaJade
Jan 27, 2008 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Samsung sh-m522c
As long as you have set the jumper at the back correctly to either master if its on its own ide lead, or slave if it's one of two on the same ide lead then if it will not play original cd's or dvd's then the drive is faulty, and you should return to your retailer.
Aug 28, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Acer Aspire 4730-4947 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
