Question about Emprex LM1704 17" Monitor
LM1704B MONITOR,DOES NOT DISPLAY ON BOOT UP,BUT GREEN LIGHT [POWER]IS FLASHING ON+OFF,IF LEFT FOR 20-30 MINUTES IT DOES DISPLAY,IF I GO TO RESTART IT IMMEDIATELY DISPLAYS[NO PROBLEM], I HAVE THE SAME PROBLEM WHEN IT IS CONNECTED TO OTHER COMPUTERS,IS IT THE INVERTER????
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Hi my emprex 17" lcd
Look for bad caps with domed tops, if you have bad one, you should repalce them in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 20, 2011
Jan 19, 2011 | Emprex LM1704 17" Monitor
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
No picture for a while, green flashing light
That is a defect with those monitors...you should get the returned to the store...if you can't then you may have to do some soldering dude...it is a power issue with the monitor itself...you will need to find the replacement capacitor inside..but still the best advice is to return the product
Oct 31, 2006 | LG Flatron L1715S 17" LCD Monitor
Emprex LM1704 17" Monitor Logo
302 people viewed this question
Top Emprex Computers & Internet Experts
David Payne
David Payne
Are you an Emprex Computer and Internet Expert? Answer questions, earn points and help others
