Question about True 49 cu. ft. / 1388 liter Commercial Freezer T-49F-RC
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
  • 4 Answers
This is a freezer and the fans work off a temp sensor located inside the evaporator. This sensor tells the fans to spin once the coil gets to a certain temp around 10 degrees most will send power to the fans. So my question is... does the coil inside the freezer actually get cold enough to send power to fans. Is it a refrigeration issue not electrical. Another thing is take a straw or wood coffee stirrer and with door switch closed attempt to spin fan with stirrer. If it doesn't spin freely and has some resistance the motor is bad) Keep me posted. (You should be able to reach your hand behind coil to feel it.).
Posted on Jun 25, 2017
  • True Master
  • 1,234 Answers
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Posted on Jan 29, 2011
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
What is the standard defrost timer control setting
Usually every 6 hours will keep the evaporator coil clear of frost. I set the time at 45 minutes per defrost. This unit has a defrost termination control that kicks it out of defrost when the coil reaches a certain temperature. The defrost timer is only a backup if the defrost control fails.
How difficult is it to replace a Door Gasket - True TS-49F Freezer
The old gasket just pulls directly out from its slot in the door. Start about 3" away from a corner, then pull the corner out; the rest is easy. Soak the new gasket in warm water before fitting; it softens the edge and makes it easier to push in.
Apr 23, 2014 | True TS-49F Stainless Steel Freezer 2...
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
My freezer has power, but the fans are not going on when the door shuts and the temperature is rising.
The defrost termination/ fan delay control is a temperature-activated, single pole-double throw switch. ).
The control is wired into the refrigeration circuit. The control is located high on the evaporator where the frost is likely to clear last. The function of this temperature-activated switch is to terminate defrost when the evaporator coil has been defrosted, and to delay the evaporator fans from coming on immediately after defrost.
The coil must reach a temperature of 25* F. for the fan delay to close allowing the fans to operate.bobicehouse_38.jpg
Jul 22, 2011 | True 49 cu. ft. / 1388 liter Commercial...
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Aug 19, 2010 | True 49 cu. ft. / 1388 liter Commercial...
True upright freezer. coil fan not running.
Let it run. Coil temperature has to be low enough for the fan delay switch to close.
Jul 14, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Need to replace, buy door lock
find model number , serial. local distributer or factory can get that for you
Aug 28, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Dec 13, 2007 | True 49 cu. ft. / 1388 liter Commercial...
True 49 cu. ft. / 1388 liter Commercial Freezer T-49F-RC Logo
400 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
