Question about Sony DAV-S400 System
The sony dav s400 system will not recognise a dvd when put in eventhough it will recognise cds. It says 'no disk'
Replace the Optical Pick Up.
Posted on Nov 09, 2010
  • lisamcgrath3 Nov 09, 2010
    Thanks will try that
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
May 05, 2011 | Sony DAV-S300 System
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Will DAV-S400 work with a Sony KDL37W5500 HD TV
Yes but only through scart cables, you will not get HD because your DVD dose not have HDMI output.
Nov 17, 2009 | Sony DAV-S400 System
Installation instructions
Hi
here is a link to download user manual from sony...
http://support.sony-europe.com/hav/ha/hta/dav/dav.aspx?site=odw_en_GB&m=DAV-S400
click on user manual tab and you will see english plus other language versions.
Hope that helps?
Dec 20, 2008 | Sony DAV-S400 System
Sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Nov 14, 2008 | Sony DAV-S400 System
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
Sony DAV-S400
You need to get a one off remote control from this company. http://www.dvdchips.co.uk/ It works I have unlocked mine.
Dec 04, 2007 | Sony DAV-S400 System
Dvd always says no disc
i had this problem for copied dvds and cds and badley scratched ones when renting. never had the problem with genuine products. it seems to be able to dectect snide dvds but my 20 quid jobby in the bedroom will play them all !!!!!!
Sep 29, 2006 | Sony DAV-S400 System
Sony DAV-S400 System Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
