Question about Colin Harrison Xming
Hello, I use w7 64 server for image application. I saw Xming running with my station with 1Gb network. I konow it work for san application with 10Gb card. I already have Melanow Infiniband switch and and PCIe cards. Who could tell me if we can use IB with Xming on W7 64? If it works...Who can support this? Sorry I am not a network specialist. Thank you.
  • Louis Basile Glaize Nov 12, 2010
    Yes i have to test IT
    Very very happy !!!
    Hello and thank you for tour answer.
    I sonder about The datarate: last tmie WE used melanox Ib card on Windows, The DATA rate was ardu 35MBytes/sec.
    WE used The melanox driver and was running corectly exept... This DATA rate with is not The 1.2 or more GBytes/sec we should gave with IB.
    With coing and putty, do WE use The full IB datarate??
    Thank you so much for all tour answers!
    Basile Glaize
    President:
  • 2,777 Answers
Xming is an independent X windows application, it does not really "care" what kind of network you are running. 1Gb, 10Gb, Infiniband ... they will all work with xming. All it needs is an active TCP/IP connection to tunnel across.
It will not look at what kind of connection you have, just that you have a connection. Then you connect through a program like PuTTY or likewise to your server, run an X Windows application or just start x windows and it will launch through xming.
So to confirm, it DEFINITELY will work with Infiniband and Win 7 64 bit.
I have it currently working on Vista 64 bit, Win 7 64 bit, and I just tried installing it on an infiniband network here at IBM and it works on all those machines without issue. Just wanted to be sure.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 09, 2010
My G3 1,5tb station does not show up on my iMac anymore. It used to work fine, without any problems and it has only been connected to my iMac. Now it does power up, but the station does not appear on my...
Check to make sure file sharing is still on at the G3. If it is running a Server app or OS X Server, make sure File Sharing Services is up and running.
Also, check the network connections on both computers. First, open the Network System Preferences pane on the G3 and write down its IP address (Note: you should have IP addresses showing on both computers, and if they use the same router subnet, the first three parts of the IP address should be identical and the last part should be different, but still between 0 and 255. If this is not so, you have a network problem between one computer and the router or other device that provides DHCP services.).
Next, on your iMac, open the Network Utility application (in Applications/Utilities). Click the Ping tab and type in the G3 IP address, then click the Ping button. If the network is good, you should get round-trip time statistics for each ping.
If the Ping test fails, then do the following steps to troubleshoot the network. Check to see if you have link lights on for both computers at the network switch, if not, check the network cable for the unlit port. If they are connected to different switches, also check the uplink port link lights on each switch. Testing a suspect connection is most simply done by trying a known good cable, a different switch port, or another computer with a known good network interface.
May 10, 2013 | Computers & Internet
I reside in San Jose Ca. Where is the nearest Toro service center?
Hello, I have found a number of service/parts dealers in San Jose... as for who's closest to you is only guess work for me as that is a fairly large territory. Here is a list of three:
Hitchcock Garden Tool and Supply, 676 Auzerais St.
(408) 998-8111
Sharpening Mechanics, 2940 Bascom Ave.
(408) 377-2568
Centerville Saw, 3516 Peralta Blvd.
(510) 793-0432
And here is the TORO dealer/service link page to see more locations. Hope this helps you out.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=2&in_hi_userid=30166&control=SetCommunity&CommunityID=226&PageID=30037
Jul 17, 2011 | Toro Lawn Mower With Toro Power Tools
My pc stoped after 30 min
Dual Channel supported up to 4GB DDR2 533/667 MHZ [XP will only see 3 GB x86 / 32bit]
Freezing is most likely caused by a faulty hard drive, or faulty RAM. I would test both for faults.
Jun 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
VMWare Clustering with Veeam or just replication
There are several advantages of clustering, as you stated, ease of server environment replication is one of these advantages. There are several others, instant fail-over replacement, swaping from one machine to the other for hardware / software maintentance / upgrades with little to no downtime during the proceedures, shared access to similar content / configurations, there are many many reasons to cluster.
you may also look into ESXi:
VMware ESXi is the easiest way to get started withvirtualization—and it’s free. Consolidate your applications onto fewerservers and start saving money through reduced hardware, power, coolingand administration costs. VMware ESXi has been optimized and tested torun even your most resource intensive applications and databases withminimal performance overhead. With VMware ESXi you can:
You can download ESXi from -=[ HERE ]=-
Nov 03, 2009 | VMware ESX Server (370598B21)
Problem configuring client station
easiest solution is to avoid their sync stuff all together, i've almost never gotten it to work correctly. what i generally do is set up the client station as a "stand-alone" and put the server address for the server name. that usually does the trick, only lick is that if the server goes down, your toast, the client goes down too.
Aug 25, 2009 | Pc America Restaurant Pro Express
Slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Aug 15, 2007 | EMC CLARiiON AX150 (AXS207500KIT) Network...
Computers & Internet Logo
155 people viewed this question
Top Colin Harrison Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Colin Harrison Computer and Internet Expert? Answer questions, earn points and help others
