Question about Intermatic HB88RC - 7-Day Programmable Outdoor Timer - 15 Amps - 120 VAC Li
HI, got a problem to start intermatic hb88rc , wont strat after programing
Http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Let's do a checklist:
> The battery has to be installed before you program timer, so that is good.
> Press Mode button and it over-rides current program ... so mode button acts as the manual override. Try manual override and see if Load comes on.
> The manual override is the real test. Plug something else into timer and use the manual override to see if timer is able to complete a circuit.
> If manual override works then your programming is suspect. (see more below)
> If manual override does not work then electric circuit is off, or timer is bad.
> After using manual override, press clock to return to current time
> Make sure Mode is not set to random
> The clock must be keeping correct time, or you would have mentioned it
> Check that the electrical plug has power.
> Check that the Load (light, fan) operates fine without the timer.
Programming problems:
> The timer program calls for ON time and OFF time for each program. If the ON time was skipped, then timer will not turn ON.
> If there is a conflict in programming, the timer will not operate as expected. For example program1 says ON at 7 and OFF at 8, but program2 says the opposite.
> Another example is when the AMs and PMs are mixed. For example you want ON at 7am TU and OFF at 7PM TU. But the timer was set for ON at 7am and Off at 7am.
> When programming, write out a schedule so there are no conflicts.
> The ON and OFF functions should follow the same days. For example ON is set for 7am TU but Off is set for ALL week.
Posted on Nov 09, 2010
How do you delete a program Intermatic hb88rc
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Sep 21, 2011 | Intermatic HB88RC - 7-Day Programmable...
I need instructions on how to program the timer. Can you sent via e-mailm a copy of the instructions? Thank you.
You posted under Intermatic HB88RC 6 button timer:
Add a comment any time.
Manual for HB88RC
If your timer is different, check timers on link below to identify your timer.
Each timer on page has manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
geno_3245_165.jpg 6 button 7-day
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
Cannot remember how to program it and have lost those instructions
HB88RC is Intermatic outdoor timer with 2 receptacles
Manual is on following page:
Choice of EZ set instructions and full manual
In few years, this manual may not be available.
To download copy to your computer.
- Open manual
- Go to File at top of browser
- Click 'Save' or 'Save page as' depending on browser
- Title and save the pdf manual
If this is not your timer, add a comment with brand and description.
Nov 20, 2010 | Intermatic HB88RC - 7-Day Programmable...
How do i program intermatic modle #hb88rc
here is the site with the manual that should be able to assist you in setting your timer
I hope that you are able to find this useful
Dec 18, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Programing
Here is a link to the instructions for easy setting your unit:
HB88RC Timer
Hope this helps!
Dec 06, 2008 | Intermatic HB88RC - 7-Day Programmable...
Intermatic HB88RC - 7-Day Programmable Outdoor Timer - 15 Amps - 120 VAC Li Logo
279 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
