Question about NetGear Computers & Internet
Hi we have problem with ProSafe Wireless-N Access Points WNAP210 which are installed together with ProSafe 16 AP Wireless Management System WMS5316. The access points keep losing wireless connection to devices even though the wireless controller says the APs are all connected and synchronized. Power off and power on of APs sorts it All connected via PoE all on one switch together Thank you
Benimur
  • 6966 Answers
SOURCE: access points
Am using for the past 5 months a LinkSys WRT300N as master with 2 WRT54G as slaves (repeaters). Both the 54Gs are using 1 of the original antenna + a rooftop mounted directonal antenna. 1 of the 54Gs is installed at a computer shop inside a school campus, the master 300N is at an office (outside the campus, a block away) and the other 54G is installed at a student dorm (3 blocks away from the office).
One favorable aspect of the 54G is that it will accept a firmware replacement; Alchemy and Talisman bySveasoft and DD-WRT by Brain Slayer, ipv6 by EarthLink, and another by Sputnik. I found the first 2 with the most features,  ease of installation and configure.
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Oct 21, 2007
sksree406
  • 61 Answers
SOURCE: wireless access point and wireless router
Connect the cable from accesss point to a switch or if you have lan slots in wireless router.Make sure that you have to give static ip to the acceess point.
Posted on Oct 31, 2008
rahul26485
  • 611 Answers
SOURCE: I have 2 3COM 3CRWE454G75 -> AP, it does work in AP repeater mode
find the ip address problem or the firewall of there or proxy servr is there and re-configure it then you get the it and check the region if not same that also creating problem sir,
Posted on Mar 06, 2009
  • 39 Answers
SOURCE: I have a cisco 3560 poe switch which does'nt seem
hi,
check physical port and cable itself.
if possible can you reboot that switch.
Posted on Sep 14, 2009
govinda123
  • 2268 Answers
SOURCE: cannot connect to access point
Are you using the Linksys utility to connect to the wireless network?
If you are using that then you can switch over to windows utility.
It is very simple to connect to the wireless network.
Click Here for More info
Posted on Oct 07, 2009
I am looking at installing a total of 9 AP's at a location. Because of this I wanted to find a solution to manage or controll the AP centrally. I was looking at the Netgear WNDAP350 AP and the WMS5316...
No- the WMS5316 is not a full wireless controller and will not provide seamless roaming. To use the WNDAP350 with seamless roaming, you need to use the Netgear WC7520, which is a full controller.
Feb 05, 2011 | NetGear ProSafe 16-AP Wireless Management...
How can I change the default management vlan (vlan 1) to another vlan # in Cisco Aironet 1242G wireless AP
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Oct 06, 2009 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Wireless AP is not broadcasting
i have several of thees routers they do not asine ip adresses
conect them to a router that assignes an ip
mine are hooked up to the network via a linksys sisco rv082
and they work real good
Apr 07, 2009 | D-Link AirPremier DWL-3200AP 802.11g...
Problem using wireless access point to conect desktop PC to WLAN
I have solved the problem:
- first, I had to change the management address in CF-WFAP into address that could be recognized by the router (i used 192.168.1.2),
- DHCP turned off, and set default gateway and DNS to 192.168.1.1. as in router, computer IP was set to 192.168.1.xxx, push "apply", change web address to new one,
- set AP mode to station-infrastructure, push "apply" buton to restart AP,
- set security to same security as in router and copy key into proper field, push "apply" again to reset the AP
- finaly check wireless station around and choose the router (same encription)
Mar 21, 2009 | Computers & Internet
Mar 04, 2009 | 3Com OfficeConnect (3CRWE454G75)...
Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Jun 16, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
Problem transistioning between mulitple Cisco Access points
Hi bab77, With a laptop, when walking around, you don't notice any problem because when a data packet is lost the network send you another one and the user don't feel it. With voice it is more sensitive because, if you loose a voice packet the user notice it right away (the call drops or you here a click or something). When walking around with your phone, your network must be "smart" enough to understand it and "pass" the call to next AP. I use the Meru Networks solution system. In this case there is a box call controller in the network that is responsible for "passing" the call to the next AP without the user even noticing a drop in the call. Hope this help (and sorry for my English) RPL4
Sep 05, 2007 | Hitachi WIP-5000 IP Wireless Phone
What is WDS?
Wireless Distribution System (WDS) allows you to make a completely wireless infrastructure. Normally, the access points must be connected with a wire (LAN). These access points create cells allowing a wireless connection. The WDS feature allows the access points to be wirelessly connected. This feature is normally used in large, open areas where pulling a wire is restricted or not cost effective and in residential circumstances. If the structure utilizing an access point is too large to cover using one AP, a second AP would be used as a wireless repeater. The WDS has forwarding functionality for extending the range of an AP. By setting up an extended service set (ESS) between access points. Stations can intersect with any AP of this ESS and move between the coverage of both APs while the higher layer network connection remains intact.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
241 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
