Question about Refrigerators
Kirland Refrigerator Ok, 3 months ago it stopped freezing/cooling. I unplugged overnight and everything was fine until today. Woke up with all meats defrosted and milk was bad UGH. Anyway, you can hear hum and then it goes off with a loud click. The fan is working.. but not cooling.Fans have been cleaned. Help! Taja
  • 828 Answers
It sounds like your compressor has failed. The hum is the compressor trying to start and the click following is the over current protector opening.
Posted on Jun 16, 2008
We have a GE side-by-side refrigerator (GSS23QGTA); it's about 6 or 7 years old and has been working just fine until about a month ago when we noticed that the freezer was not freezing food. The temp had...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 16, 2011 | Refrigerators
Kenmore top mount refrigerator bought new in august 2010 - kept in a heated garage. have not had to use the freezer compartment up until now. we put meat in it and the meat got cool but did not freeze. ...
The refrigerator compartment thermostat may be the culprit. If you can remove it, you can check its calibration with iced water. Make sure you check the fan motor and the fan blade condition.
Dec 16, 2010 | Refrigerators
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
Jun 24, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Frigidaire GS26HSZCC7
it sounds like it could be the defrost timer/board hanging up in defrost periodically. this refrigerator has an adaptive defrost control board that acts like a defrost timer. it keeps track of how long it takes the freezer to defrost and schedules the time between defrost cycles accordingly (to save electricity). old defrost timers would go thru a defrost cycle every 12 hours whether it needed it or not. so i would suspect that this control board may be malfunctioning. the control board is item # 1036287 at repairclinic.com. you will need a repair technician to test it and make sure it is bad before spending $75 on it.
Jul 10, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Freezer is only cool, everything melting
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
