My laptop heats up then shuts down have an hp pavilliondv2000
    President:
  • 1,851 Answers
The first step is to clean up the air ventilation blinds. Shut down your laptop and remove the battery. Use a soft brush (and if possible air under pressure) to clean up pedantically the air blinds all around the laptop. In case of using air under pressure leave the laptop to "rest" (and the temperatures and humidity to balance) for about 15 minutes. Check for your problem again after this. If the problem insists you may have a faulty fan. In this case you have to open the laptop's case and replace the fan. This procedure isn't very easy and I suggest visiting a service center or a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Nov 09, 2010
Hi.. i have hp pavilion laptop and the problem is my laptop shutting down automatically at startup
The fan is probably stuffed with dirt, making it difficult to rotate. And if the processor doesn't get enough cooler (fan) it will heat up and burn. Thats why it keeps shutting down. The shutting down is actually protecting your pc from serious damage. So try cleaning the fan with a vacuum cleaner. Be careful not to use too much pressure. Goodluck
Aug 13, 2014 | HP Pavilion Computers & Internet
Hp compaq f750us fan will not come on unit shuts down? Why
If your laptop is on and shutting down because it is over heating then you dont have much choice but to replace the fan. Which you can check this manual. Starting at page 71.
http://h10032.www1.hp.com/ctg/Manual/c01295900.pdf
Or.........
You could try something like this. An external cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16834997396
Feb 02, 2011 | HP Compaq Presario F750US
My laptop keeps shutting off it is a hp pavillion dv6000
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 16, 2010 | HP Pavilion dv6000z Notebook
Shuts down randomly
check if the Notebook shutting down due to heat sinking. Make sure the heat exaust panel cleaned properly. Also uncheck the option "automatically Restart" from Startup and Recovery.
May 03, 2010 | HP Pavilion ZV5340US Notebook
It shutdown suddenly while working
If Ur Laptop Shutdown While Working. Then First Check Out Your Bettery Life. If It is ok Then Make Sure Your Laptop Didn't Heat more. If Still You Face Problem Then Contact Hp Care No : 1800 112267.
Jul 29, 2009 | HP Pavilion TX2000Z Notebook
It shuts down
hello, try to clean your fans from dust. also if you can test your power adapters voltage and W.
Feb 23, 2009 | HP Computers & Internet
Hp laptop shuts itself down
Laptops are designed (by software) to shut themselves off as a protection measure. The most common problem is high temperatures. Do you hear your fan racing while you are using it? Do you sit your laptop on soft surfaces (like the bed or carpet floor) while using it? Do you smoke around your laptop while using it? These are common things that cause high temperatures on your laptop and will cause it to shut down. May not be your case but just a though. I would take it somewhere or open it up yourself(if you are pass your warranty time ONLY) and clean out the dusk with some air.
Hope this helps!
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion dv5-1000us Notebook PC
HP Pavillion ze2000 loses power
I had a laptop just like that and it ended up being that the cpu fan and heatsink was coated with dust. do you have pets or dusty house?
Dec 18, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
