Question about ASUS Eee 4G Notebook
I am trying to reformat my asus eee pc1005HA laptop. It is asking me for a CURRENT password, but Ihave no idea what I set it as over a year ago. When I called support they said they could only give me a master password to reset if I sent them my original receipt from where I bought the device (best Buy from over a year ago.) I dont have it.
  • KAMILADD
    KAMILADD Nov 09, 2010
    Hi, thanks so much for your help. The laptop has windows 7 starter. It did not come with a re-installation disc (as it doesnt even have a disc drive.) However, I do have my own windows 7 installation disk and I am wondering if you could instruct me on how to create a usb stick from it. I dont have and external dvd drive, but I do have a desktop PC and plenty of usb memory sticks. Thanks again!
  • KAMILADD
    KAMILADD Nov 10, 2010
    Hi. I just began the process you last instructed me on. When I was in the command prompt I typed list disk, but the only object/disk listed seemed to be my hard drive (112GB) at #0. I plugged in the usb stick to both the front and back of my PC, but it didnt appear to show up either way. Any suggestions? Thanks.
  • ASUS Master
  • 13,433 Answers
Hey,
In that case you can't restore the machine from the recovery that comes with it, you would need either a USB stick or a USB dvd drive to perform the install from an original windows disc.
You did not say if the laptop has linux or windows 7 starter.
To reinstall windows 7 starter, you need to use another computer to make that special usb stick with the contents of the windows 7 DVD. Or you can use a USB CD-DVD drive to install from the windows 7 DVD.
Making the usb stick will be much more complex compared to using a external dvd drive.
I've written instructions on how to install windows 7 here
http://www.fixya.com/support/r3575598-step_by_step_howto_install_windows_7
Before you go get into installing windows 7 from the external drive you need to enter the bios of the computer to change to boot order so that the USB CD ROM is the first device the computer attempts to start up from instead of the hard drive. After that you can follow the instructions on the above linked page. In the windows 7 setup you must select the version of windows that you have the key for, if the machine came with a w7 starter, you need to take that, since the key in the bottom of the laptop will only work with that edition.
If you have any questions or anything, add a comment and I'll respond as soon as possible.
Posted on Nov 09, 2010
  • 1 more comment
  • Ekse Nov 09, 2010
    For changing the boot order, take a look at this pagehttp://www.fixya.com/support/r3575592-un...
  • Ekse Nov 09, 2010
    Your going to need a usb stick with around 4 to 8GB of space. when I last did it It went fine into a 4GB usb stick but that was vista.
    So your going to need the win 7 disc and a usb stick.
    Plug in your usb stick and copy all the important content off of it.
    open command prompt with administrator rights, by typing CMD in the start menu search box and hit CTRL+Shift+Enter (did windows 7 have this? Vista has the seach box in the start menu)
    If you don't have a search box in your start menu, download this file http://ekse.pp.fi/admin.cmd and save it to your desktop. right click on the file on your desktop and select run as administrator, it will start CMD.exe as an administrator.
    In the prompt write diskpart and hit enter.
    Then type list disk, note the disk number of the flash drive. it will be the disk with size around 4000mb or 8000mb or 4 / 8 GB
    lets say your pendrive is disk 3 (replace it with your own number)
    Then enter the following commands in diskpart and hit enter
    Select Disk 3
    Clean
    create partition primary
    select partition 1
    active
    format fs=ntfs
    assign
    exit
    Next insert your windows disc in the drive, find out what is the drive letter of your dvd drive and what is the drive letter of your usb stick then go back to the command prompt
    Enter the drive letter of your dvd drive and hit enter like this for example if it was D drive then below (and don't forget" : " without the quotes)
    D:
    Next enter CD BOOT
    write bootsect.exe /nt60 F: ((Where the F is your USB Sticks Drive letter))
    Now we are almost done, copy your windows 7 dvd contents (everything from the dvd drive) into the usb stick
    Should work.
  • Ekse Nov 10, 2010
    Sounds like your USB stick is faulty, try another one. 4GB should work.
My asus PC1005HA will not re boot after I upgraded BIOS
closed the unit down
now press the start button and hold down the delete button to get it to start in bios
check the boot sequence there
adjust as required and save
Aug 17, 2017 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS Eee PC 1000HE bios password
REMOVE BIOS PASSWORD
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc or copy to the USB memory stick to run them.
Jan 19, 2013 | ASUS Eee PC 1000HE Netbook
Asus eee hard disk locked and it asks for master password, I don't know it, how can I get around it? Or what is it?
You have too choices, reformat the hard drive," warning " all personal data and password will be erased, or you can go to www.ebay.com type HDD password and go through the list of sellers.
Jul 19, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
User Manual for ASUS EEE PC1005ha Netbook with Windows XP
good day sir. here is a link where you can download it:
http://www.usermanualguideonline.com/laptop-notebook/asus-eee-pc-1005ha-manual-user-guide.html
just select the word "here" at the end and save it to your PC. its a pdf file. hope this help sir. goodluck. please rate my answer. thank you
Apr 23, 2011 | Computers & Internet
I WANT TO GO TO ASUS NOTEBOOK BIOS SETTINGS BUT IWHEN I DARE GETTING INTO IT, IT NEED THE CURRENT PASSWORD, WHAT IS THAT PASSWORD, CAN I HAVE IT?
The password is a password that was set when the first user set the notebook up. There is no record of it except by the person who wrote it.
Dec 17, 2010 | ASUS Eee PC 900 PC Notebook
ASUS EEE PC w/ Windows XP will not Connect Wirelessly
You need to know if your home network requires a password or paraphrase to allow you to connect. Also, you might have to check your settings on your router, they have to match the settings of your laptop wireless adaptor. You can try these solutions and if no luck post with more information
Jul 03, 2009 | ASUS Eee PC 900 Notebook
Not remember password.
If your not running Windows, the first thing I would do is write to Asus and ask them if they left an administrator account on this machine. Most of the time if your using linux and you forgot your password. then you just have to reinstall Linux. Most Linuxs' have a root account that you could log into to do maintanance but if they disabled this account then your going to have to reformat everything. Linux is very secure but sometimes that works against you if you don't take passwords seriously.
Jan 20, 2009 | ASUS Eee 4G Notebook
How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
Jan 13, 2009 | ASUS Eee PC 900 Notebook
ASUS Eee 4G Notebook Logo
170 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
