Question about Zeiss CONQUEST 3-9X40 MATTE Z PLEX
On my ziess conquest, what turning knobs do what? which one makes it go up and down and which one makes it go left and right?
    Sniper:
  • 58 Answers
The top knob should be marked with a "U" and an arrow pointing clockwise. Turning this knob clockwise should adjust point of impact Up, and turning it counter-clockwise should move it Down.
The knob on the side should be marked with a "R" and an arrow pointing clockwise. Turning this knob clockwise should adjust the point of impact Right, and counter-clockwise is Left.
Posted on Jan 14, 2011
  • jlclark334 Apr 17, 2011
    Mine works back to front also.
    If i need impact to move up i have to turn the turret to the left
Why don't I have sound on uniden pc78ltw?
the knob that turns the radio on and off is the volume potentiaometer.turn it 1/2 wayopen.the next knob is the squelch maqke sure it is all the to the left.the next knob is the mic gain and the RF gain.Set the mic gain at 1/2 and the RF gain all the to the right.the next knob is the delta tune,set it 1/2 way the next knob is the calibration knob leave it alone.Now above those knobs are little switches .the third switch from the left is for CB/PA make sure its on CB. check the WX switch and make sure it not on a weather station. and finally the last switch to the right is called a dynamic squelch switch.Make sure it is down. with all said your radio should be on and you should be able to hear sound. If not ,take an external speaker and hook it to the external speaker plug in the back of the radio.If you hear something then you internal speaker is junk.replace it .
Sep 04, 2014 | Radio Communications
Owners manual for conquest 3-9 40 ziess scope
Sound like you are looking for an owners manual for a Zeiss Conquest scope? Check out RCS Optics, they are an authorized dealer for Zeiss and have free downloads here:
Zeiss Conquest Scope Owner Manuals
Hope that helps out!
Sep 30, 2013 | Zeiss Optics
How do i zero my tasco silver antler rifle scope
Start out at 25 yards. the scope is I believe used 1/4 inch clicks. This is for 100 yards so 16 clicks will equal 1 inch at 25 yards. Fire three shoots from a solid rest. Measure the distance left or right and up or down from the desired point of impact. and move the setting in the desired direction. ie uo is moving the point of impact up from where it is. and left or right is the same. Next fire at the desired distance and move point of impact to where you want it at that distance. If the scope is wandering all over the target make sure the scope is not moving in the mounts. If it persist in changing point of impact send it back to tasco for a replacement as it has a loose recticle. Better yet I can recomend Leupold or Burris as a better alternative if they are in your budget. Not quite a S&B or Ziess but **** close for a lot less $$$$$
May 24, 2012 | Optics
Hi I sighted inmy rifle today with a Ziess Conquest scope. When i needed to bring the point if impact up . The impact moved down instead. I turned the scope turret to the right like the markings on the...
I hate those 'direction' arrows. I usually end up ignoring the arrows and moving it however it takes to get what I want.
Raising the crosshairs will cause you to have to point lower to make the round hit on target.
Oct 12, 2017 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Dont understand why on top of an side of scope setting there is ur ur instead of left right or up down
The "U" indicates Up on the elevation dial, and the "R" indicates Right on the windage dial. Turn the elevation dial clockwise to move the point of impact up, counterclockwise moves down. Similarly, turning the windage dial clockwise moves Right, and counterclockwise moves left. Here's a scan from the Zeiss Conquest manual:
Jan 05, 2011 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
How to set clock
go in to the menu by holding the button down for a second. find the clock adjust, put in the correct time. if you make a mistake repeat steps till you get it correct.
Sep 19, 2010 | Kenwood KDC-MP235 CD Player
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
I can't pull out the filter
Make sure the filter is turned all the way to the unlock position, then get some pliers and grab the turning bar, and pull.
Make sure there is nothing in front of the filter that you have not removed yet.
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Zeiss CONQUEST 3-9X40 MATTE Z PLEX Logo
215 people viewed this question
Top Zeiss Optics Experts
obsteiner
Andrew Taylor
Andrew Taylor
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
