Question about Cuisinart DGB-500 Coffee Maker
Cuisinart grind & brew coffeemaker DGB-500C
Hi, had my coffee maker for about 3 yrs. It turns on and starts to brew but will stop completely, will sit not working, then it will suddenly start again and finish abouy 10 mins. later-----any suggestions?
  • Anonymous Jan 06, 2009
    serial # 302210 Model # DGB-500
    We try to make coffee and it will start to brew then shuts off, the clock, timer, everything. The screen goes dark.
    It takes us about 3 hours to make a pot of coffee. I thought buying a name brand like Cuisinart would give a mdicum of quality.
    Cuisinart----Cuisin-JUNK $169.00 Broken Decker gave better use...
    Joe
    bern@ekns.net
  • 8,596 Answers
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Gd morn. My CBC5200PC will brew only a partial amount of the water. This morning it stopped at 6 cups, then I coaxed it by turning it off and on,, but would only drop a cup of water at a time
Brewing Problems
Another common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again. (From. Google Search)
May 17, 2017 | Coffee Makers & Espresso Machines
Need manual fordgb300bk
Here is the link (this is for a mac) Cruisinart COFFEE BAR Automatic Grind Brew DGB 300 SERIES MANUAL...
or there is a website called manualonline.com
Mar 16, 2014 | Cuisinart DGB-300BK Automatic Grind & Brew...
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Our Mr. Coffee (model JWX27--it's less than 2 yrs old) stopped working out of the blue. The lights all seem to work, and the clock, but it doesn't start the brewing cycle. I've checked the timer/delay...
The heating element has gone bad. Since it is not a user-serviceable part, I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Mar 01, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Disassembly instructions - will not grind
watch this video http://video.cuisinart.com/video/video.php?s=cuisinart&t=demo&f=Cuisinart-DGB-650BC-Automatic-Coffeemaker its from cuisinart.com this may give u the complete answers and instructions to your problem,,,thank you for using fixya.com
Feb 11, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Hi, My machine starts the process allright. It grinds and starts brewing. A few drops comes through, then it just stops and a red light shines up. I have tried to remove some parts and cleaning them. It...
Sounds like the grind is too fine. If its (the big knob) below 8 in the bean hopper, turn it to 16. You can turn the knob to a larger # anytime but you have to be grinding to turn to a smaller #. Make 3 coffee but push the button when it starts to brew to stop the brewing until you get to the third coffee and just let this one brew. If it brew correctly then turn the knob down to a # a couple higher than you had before.
Sep 21, 2010 | Saeco Vienna SuperAutomatica Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
504 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
