Question about Dell Computers & Internet
Dell latitude D 610 battery dead
I need a new battery for my dell latitude but it has been fine working on AC power until the other day. It won't turn on at all now even when plugged in. Is it just because I need a new battery or is there another problem?
    Problem Solver:
  • 16 Answers
dell latitude batteries have a built-in battery life indicator on it. Press the button to see how much charge is left or if there's no charge at all. It sounds like your power adapter isn't charging
your battery. visit: http://accessories.us.dell.com/sna/batteryconfig.aspx?c=us&cs=19&l=en&manufact=694&s=dhs&stype=4&family=Latitude%20Laptops and choose the model of your latitude laptop.
u can get it cheaper on ebay or any 3rd party vendor. hope this helps.
Posted on Jun 16, 2008
Dell Latitude D810. I bought a new powr supply from dell. I keep getting a popup saying that it cannot determine the AC power adapter. Also, my battery is dead.
You will get this error when you get a newer power supply than what was originally design for the Latitude, also when the unit came from a 3rd party supplier not on Dell's OEM supplier list, and your battery will some what solve this upon getting a new one.
As for the pop up itself, no harm. Just a nusance. You should be able to turn this off in the Administrator file and select services. Look for power management and deselect monitor AC power.
Good Luck.
C2Solutions
Jan 24, 2011 | Dell POWER SUPPLY Power Supply
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
When I unplug the printer from my Dell Latitude D610 laptop, the battery icon appears on the bottom right hand corner instead of the "ON AC power" icon and the computers shut down due to a low battery....
Your AC power supply is not providing power - The printer is supplying your laptop with power via the usb port. When you unplug the printer, the laptop runs on battery until it goes dead. You will need another AC power supply,
Good Luck
Oct 03, 2010 | Dell Latitude D600 Notebook
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Dell latitude 810 will not power up and says low battery
if you plug in to charge your battery and its not charging replace the battery with a new one and a ac adaptor plug, just to avoid any more damage to your pc notebook, dont try to repair if you are unsure on what to do
Nov 23, 2009 | Dell Latitude D810 PC Notebook
My Dell610 laptop says that it can not recognize
you need a 90 watt power supply,the one you have is bad
Sep 05, 2009 | Dell Latitude D600 Notebook
My d600 will not run on ac power. I have an old battery which also will not charge. I have tried two different dell adapters and both will not power the unit. With the battery out, running on ac it is...
if you are sure that both power adapters are fine and it is still not working then you may have an internal fault or the pin inside may be damaged..
Aug 27, 2009 | Dell Latitude D600 Notebook
Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
aneesnv@msn.com
Dec 18, 2008 | Dell Latitude D600 Notebook
Charging Problem
go back to old bios if u can
Jan 21, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Computers & Internet Logo
257 people viewed this question
Alun Cox
