Question about Mongoose Cycling
I have a mongoose rockadile 2010 mountain bike, how do i adjust the height on the handlebar?
    Scholar:
  • 71 Answers
I have never fixed this bike but normally there is an allen wrench bolt right on top of the shaft you have to loosen it (not take it out there is a tightening nut at the other end of the that you want to stay on) then after it is lose you should be able to adjust it but if not you will have to loosen or take of the first bolt down the shaft and that should make it able to be adjusted i hope this helps
SabiousOne
Posted on Nov 09, 2010
How to raise handlebar
Open the Allen screw in the center of the handlebar stem by about 2-3 turns, then wiggle left and right until you have the proper height, retighten screw
Mar 12, 2015 | Mongoose 2008 Teocali Comp Mountain Bike
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
I'm trying to replace the handlebars ona 26"
It's not clear what she did to modify the height. Most strategies are here:
http://sheldonbrown.com/handsup.html
If you surf the web for "bicycle handlebar stem adjustments" you will eventually find something that looks like what it IS right now. I suspect you may want to UNDO the modification. You could engage a bicycle shop and save all the research, parts procurement and labor. OR go surfing.
Sep 23, 2011 | Huffy Alpine 26 Women's All Terrain...
I want to adjust my handlebars from mountain biking position to street riding. How do I do that?
One man's road position is another man's mountain. Which DIRECTION do you wish to go with them?
Depending on its current orientation and deviation from 90 degrees (known as rise) the stem could simply be flipped to change the height.
Read this...
http://www.sheldonbrown.com/handsup.html
Google "how to change handlebar height" for videos.
Jun 27, 2011 | GT Timberline LTD
Is it possible to increase handlebar height on a 21 speed Exile?
Within small limits.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Jun 01, 2011 | Mongoose Exile Dual Suspension Men's...
We would like to raise the handlebars on a Mongoose Rock River Mountain bike but there doesn't seem to be a way to do it. We have no manual as it was purchased used. Thanks
Maximum height was determined when the bike was built and they sawed off the steerer tube.
There is no way to raise the stem vertically, short of getting a new stem that has a higher rise.
http://en.wikipedia.org/wiki/Headset_(bicycle_part)
Feb 20, 2011 | Mongoose Cycling
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
157 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
