Question about Garmin zumo 550 GPS Receiver
Garmin zumo 550 cannot find satellites
When switched on and taken on an over 2 hour trip into south downs area my zumo 550 has, today, failed in all that trip to find ANY signal from satellites. My Garmin Etrex, switched on alongside it, finds signals enough to navigate to 17 feet, within its normal time span. I've pressed Off and the Plus to no effect. When it comes on, after a time spent searching, it asks 'Are you indoors?'. Then 'Are you in the UK?' Then 'Is it 6th October 2006?'
I've now flattened the battery in order to retry it later tonight.
Please suggest whatever I can do short of buying a make of GPS that works.
  • jsabados Jul 03, 2008
    Same problem here. Battery is fully charged. Unit is fully updated. Sometimes the unit will not find any satellites for an in town (Tucson, AZ, USA) trip when first powered on. Sometimes it can take 10 miles or more to find them. Once (if) it finds them it doesn't loose them until I turn the unit off and then back on. Once it turns on again, it can take forever to find the satellites again. I am only getting one red signal strength bar at power-up. I first noticed this after the most recent upgrade to SW version 4.20. Any help would be appreciated
    Scholar:
  • 174 Answers
I'd remove the battery first, leave it out some time, put it back, fully charge it and use webupdater to see if all is up to date. There is a test menu on the Zumo to see if all works. I will tell you how to get there, only after you have tried the above first!
Posted on Jun 16, 2008
My zumo 550 is still looking for satellites
If you have traveled with the unit lately you may need to let it sit and acquire satellites for up to 20-30 minutes. Also your unit may need a firmware update. If none of these work try purchasing an external antenna this may fix your problem.
hope this helps!
Feb 07, 2011 | Garmin zumo 550 GPS Receiver
Garmin Zumo 550 won't come back on after a trip of about an hour.
There's a small screw on the back that needs a torxs screwdriver.
Aug 23, 2009 | Garmin zumo 550 GPS Receiver
ZUMO CHARGING STATUS
I have had Zumo 550 for 2 years now, and it does exactly the same.
I think it is just the way the unit is, and is not a fault.
Feb 14, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 vehicle file
Instructions taken directly from the Garmin website
How to Install:
  1. Connect your Garmin GPS device to your computer.
  2. Click Download.
  3. Click Open, if necessary.
  4. Click Extract.
  5. Browse to find the “Garmin/vehicle” folder on the Garmin drive. You may need to create the vehicle folder.
  6. Double-click the Unplug or Eject icon in your system tray. Click Stop, and then click OK.
  7. Unplug the USB cable from your Garmin GPS device.
Jul 28, 2008 | Garmin zumo 550 GPS Receiver
GARMIN ZUMO 550
Have you checked the firmware updates through webupdater (on the garmin site)
Have you ever erased all user settings? To do this press and hold the right bottom of the touch screen while the zumo is powwered of, then press power on until the screen pops up, select yes to erase all user settings, it will now startup clean and request you to set the GPS up. Press and hold the clock will pop up the system menu. Any SD cards installed should be removed, just to make sure that's not the case. To see if your antenna is bust, connect an external antenna. I still have my streetpilot 3, rugged as hell, just a bit crappy memory wise, but back in those days it was THE SOLUTION!
Jun 17, 2008 | Garmin zumo 550 GPS Receiver
GARMIN ZUMO GPS 550- how to i connect power source to my Harley mc and speakers?
Red lead to the plus and black to the minus of the battery, connecting to the speakers youl'll nead something with an aux input, or a small amplifier, the output signal of the Zumo is just enough to power a head set!
May 26, 2008 | Garmin zumo 550 GPS Receiver
Lines Running North and South
How do you load maps? and are these Garmin maps. I try to keep the Zumo original and use an SD card for extra maps. Did you try this yet? And if you are using SD cards, try a different brand/quality. I had some lockups with crappy budget cards. Kingston, Sandisk and some other A brands work fine!
Oct 16, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550 Trip Log
In one of the menu's you can select the trip log to be visable, press wrench, press map, press to the right of triplog to switch from visable / hidden. press back, press user settings and there is manage trip log. BTW all this info can be found in the Fine Manual!
Oct 15, 2007 | Garmin zumo 550 GPS Receiver
Transfer Problems
I locked my garmin zumo 550 and forgot the passcode
Oct 11, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
448 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
