Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
I lose my camera, does a warrenty help with that? and if i don't have a warrenty, how much would it cost to get a new one?
I lost my camera on a class fieldtrip. i left it on the bus by accident, and they ddidn't seem to be able to find it.
    Novelist:
    Champion:
  • 216 Answers
Greetings jklolrotfl,
Unfortunately most warranties do not cover loss. The only recourse you may have is if the method of payment was a credit card that offered some sort of coverage for theft or loss of unit.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Posted on Jun 16, 2008
Can you please tell me the secret getting the cover? My monitor shuts off after acouple of minutes.If I wait 30 minutes or so it will turn back on. But just for acouple more minutes and it off again. I...
That sound like you have a component failing inside. Basically what you are seeing is the part heating up and then stopping. It cools off a bit restarts and you get a few minutes and it heats up enough and off it goes. If you have any warrenty talk to the store you bought it from and see what the process is to get it fixed. If you don;t have warrenty this can be iffy if it is worth fixing or just replacing. The repair can easily cost more than a new one. You might want to check around as well as talking to acer and the store about repairs. Don;t just get it fixed just an estimate. Do a bit of shopping and see what a new one is worth. If the new one is cheaper just get it. The repairs can be long or short term fix. It might get t working for a while or for a long time but you don;t know so unless the repair cost is cheap don;t bother and expect to see a problem sooner or later.
Jan 21, 2011 | Acer AL1916W 19" LCD Monitor
Distance photo can not capture but close ok
I wonder if your autofocus is having problems. It may never get a distance number and is just sitting there waiting for it to figure out how far things are.
There is no other real difference when taking close or far just the focus. If you take the camera and set it to manual focus to try and take some distance shots. If that works then that is the problem.
As far as fixing it that depends on the value of the camera. Unless it is one of the higher end cameras the cost of repairs will be more than a new replacement camera. If you have warrenty this is covered. So check out your warrenty, check out the repair cost estimate, and check out what a new camera will cost. If you don't want to spend the money then your only option will be to learn how to do a manual focus for distance shots. It isn't hard just take a little practice. Unlike close photo's distance ones are not that picky for focus.
May 05, 2010 | Cameras
Screen went blank or out
9 times out of 10 this is the backlight system going out. Either the backlight source (bulbs) or thier power supply. If you look at it when the computer is turned on you will see the desktop but very ghost like. You might have to get close and to one side to see it. If you are handy you can repair some monitors with a repair kit. The repairable ones have the backlight systems on seperate boards so you can just unplug the old one and put in the new one. Basically you can count on spending around $100 to repair it. So the first thing you need to do is check to see if you have any warrenty at all. If you don;t then you need to look at the replacement cost of a new monitor verse the repaired monitor cost. Usually the new monitor is as cheap and has the benefit of a new warrenty.
Mar 31, 2010 | ViewSonic VX1935wm LCD Monitor
My Polaroid i1035 won't stay on. It comes on when
That usuallymeans an internal problem. So it needs to see a repair shop. Check for warrenty repair and replacement cost. Sometimes it is almost cheaper to just get a new camera.
Mar 23, 2010 | Polaroid i1035 Digital Camera
L have changed the batteries l can see the green light flashing but l cant view the monitor,,is blank....totally black,,,what shall l do,,,,please help....thank you.....
Two things. One is the lcd is out and needs replacement or hopefully you accidently turned it off or the batteries got too low and the camera turn it off to save power. I don't have the manual in front of me so you will probably find out how to turn it back on under the config menu.
The display going out is common but the repair cost is not cheap so if you don;t have warrenty make sure the repair cost isn;t going to be more than buying a new camera.
Mar 23, 2010 | Nikon Coolpix 5600 Digital Camera
My lense is not rotating out and now is disabled
If the lens isn't coming out then the drive or the gears are toast. If you don;t have warrenty this can cost as much as replacement camera to fix. Contact Canonsupport and they can tell you how much.
Mar 22, 2010 | Canon PowerShot A560 Digital Camera
E-300 need to replace the built in flash
you are going to have to replace the camera to do that. The parts will cost as much as a new camera. Unless you have warrenty it just isn;t worth it.
Mar 22, 2010 | Olympus Cameras
Ii bought a vivitar camera a vivicam 8325.. on the 26th of nov 2009 but i have lost the warranty can you help .. many thanks john welsh
Hello
I just recently found out that you don't always need the warrenty slip, in order for you to still have the warrenty permissions on the device.
All you need to do is do go to the store where you baught the camera, tell them that you lost the warrenty slip. THey can look at the serial number on the camera and will be able to determine when and where you baught it.
Thus they will print you out a new warrety slip.
Hope this can steer you in the right direction.
Kind regards
Andrea
Dec 24, 2009 | Vivitar ViviCam 35 Digital Camera
Please help
You can download it from here.
http://www.sakar.com/p-254.aspx?return=y&txt=28290&page=0
Click on download drivers.
Feb 22, 2008 | Sakar 24280/24282 Digital Camera
My camera c633 takes photos but flash wont work????even with new batt???
It is eathe the bulb or the flash circuit. if you are going to fix it yourself watch out for the flash compasitor. If you are going to send it in watch the cost. It sould be fairly cheap to have fixed.
Dec 31, 2007 | Kodak EasyShare C633 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
18 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
