Question about Vcomm Recovery Commander (804526023624)
Annoying Recovery Commander is interfering with my computer settings. XP Home, SP3 Microsoft IE ..All updates in place. I want to be rid of this very annoying utility!
luciana44
  • 292 Answers
SOURCE: Recovery Commander Starts always and annoys me.
This problem usually happens, ehen you do not do the Shut Down process properly.
Close or save( if modified ) the document or spreadsheet. Then close the program before you shutdown the computer going through the Shutdown command instead of the OFF Switch.Hope this will solve your problem.
Posted on Aug 22, 2009
SOURCE: need to uninstall recovery commander ..don't know how
Open System Suite 8, on the left you will see the task menu, open recovery, in recovery open the create a check point task, uncheck all the boxes with a checked next to it, that should disable the recovery commander part of Systems Suite 8.
Posted on Sep 22, 2010
SOURCE: How do I disable Recovery Commander on Windows 7?
For you to Stop it you need to stop the services running for it. Follow the steps below.
Click on Start and then Click on run. Type msconfig. In the System Configuration utility screen click on services tab (Its on the Top). Once you are on that screen check the option Hide all Microsoft services. Then look for Recovery Commander. Uncheck that. Uncheck the Hide all Microsoft applications again. Click on apply. Then click on OK. Reboot the computer. You will System Configuration utility screen. Check the Option Don't show this message again and then click on OK.
Note: DO NOT uncheck any Microsoft Services.
If you want to delete it or remove it from the computer then install Revo Uninstaller (Freeware).
Posted on Dec 18, 2010
SOURCE: I want to get rid of 'recovery commander' from my
There is an application called Revo Uninstaller (Freeware). Install it on your PC and then uninstall recovery commander.
Hope this helps.
SOURCE: Recovery Commander (804526023624): recovery commander pops up whenever i try to do an...
I need to download windows xp to install on my 2nd computer
You cannot download Windows XP unfortunately. You may be able to purchase a copy on Ebay. You will need your own installation key which should be on a sticker attached to your PC.
May 11, 2014 | Microsoft Windows XP Home Edition
Slipstream post XP sp3 updates
The same way you slip streamed SP3. You can download all the updates here. http://catalog.update.microsoft.com Alternately you update your system to a base install get all the updates and create a ghost image.
May 11, 2013 | Microsoft Windows XP Home Edition
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
How do I disable Recovery Commander on Windows 7? It's so annoying that every time I launch a MS Office application the Recovery Commander is launched.
Sep 21, 2010 | Vcomm Recovery Commander (804526023624)
I HAVE A 6 YEAR OLD DELL WITH SP 2. IS THAT THE LATEST UPGRADE?
The latest service pake for XP is SP3, you can download and install it by performing a Microsoft Update by clicking on the the start menu and above where it says "All Programs" look for Windows/Microsoft Update.
Once SP3 is installed i recommend you perform another MS update to update SP3.
Regards.
Jun 26, 2010 | Dell Microsoft Windows XP Home Edition
Downloaded Windows XP Update SP 3. Now system
When you installed SP3 it was also placed into Add/Remove programs, (In control panel). Boot the system and enter safe mode. Uninstall SP3.
See also Microsofts instructions on how to remove SP3; http://support.microsoft.com/kb/950249
Did you find this helpful
Mike
May 21, 2010 | Microsoft Windows XP Home Edition
Cannot update from XP Home SP1 to SP2 or SP3
start out with a xp home disc that has sp3 already Intragated on the disc - windows xp home SP3
Sep 03, 2009 | Gigabyte GA-K8VM800M Motherboard
Need to uninstall recovery commander ..don't know how
Jul 03, 2009 | Vcomm Recovery Commander (804526023624)
SP3 nightmare install
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07159&lc=en&dlc=en&cc=us&product=1127351&rule=24868&lang=en#
This should help you also
On March 6, 2008 Microsoft released Service Pack 3 (SP3) for Windows XP. Service Pack 3 contains all of the important Windows updates from previous service packs as well as additional updates that were released after Service Pack 2. To install Windows XP Service Pack 3 from the Internet on a home desktop computer use the Windows Update feature. CAUTION: If you have an HP Pavilion, HP Media Center or Compaq Presario desktop computer that has an AMD processor, your PC might encounter a startup problem after installing SP3 (or SP3 will not download from Windows Update). Before attempting to install SP3, install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors . For more information, the following support articles from the Microsoft Web site can help: 322389 - How to obtain the latest Windows XP service pack (in English) 936929 - Release notes for Windows XP Service Pack 3 (in English) NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jan 25, 2009 | HP Compaq Presario SR1620NX...
Scratching on glossy photo paper
Unfortunately, you may have to revert back to SP2. the thing with sp3 is that it can act and work completely different from computer to computer depending on what software you have installed on it and what build of XP you have (ie home/pro) The only other alternative is to uninstall software, reboot and see if the problem persists. this way you may be able to find the program interfering with the performance of your printer.
Dec 19, 2008 | HP Photosmart 8750 InkJet Printer
Vcomm Recovery Commander (804526023624) Logo
164 people viewed this question
Top Vcomm Computers & Internet Experts
David Payne
David Payne
Are you a Vcomm Computer and Internet Expert? Answer questions, earn points and help others
