Question about Ezonics EZ-326 Webcam
Driver to install my camera to my personal computer
Give me software to intall in computer
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 19, 2012 | Logitech QuickCam Communicate STX Personal...
Camera will not work on oovoo/skype. New computer
1st You download Webcam Driver. PC Camera Intel Driver Windows 7 After this install the Webcam driver in the system.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 15, 2010 | Intel Pro PC Camera CS430 Webcam
I can not insttal my webcam how i do it? my webcam viewsonic 'vx2255wm
Here's the Webcam Installation (taken from user Guide)
  1. Insert the Webcam Wizard CD into your CD-ROM drive, and follow the screen instructions to install the program.
  2. Connect the monitor to one of the computer's USB 2.0 ports, using the USB 2.0 cable that is included with the monitor.
  3. The computer will detect the camera automatically and the webcam icon will appear in the My Computer window.
  4. Please refer to the Webcam User Guide on the Webcam Wizard CD for detailed instructions on using the webcam.
here i include the Webcam Driver:
http://www.viewsonic.com/support/downloads/drivers/_download/VX2255wmb_WebCam_Utils.zip
(simply click on the link to download the webcam driver)
hope it help
regards
Apr 17, 2010 | Computers & Internet
How do we install a web cam in our computer?
Like any hardware, you will need the software "driver" that makes the camera work on your pc. If you have a software disk, there is probably a manual or set of instructions on the disk.
Usually you put the CD in your CD drive and it may well start by itself. If not, look for the "set up" icon, if you don't see that, look for a driver folder. The drivers should be organized by operating system.
Install the driver, or copy the driver to a location you can easily find on your hard drive, like you 'my documents' folder. Then restart your computer and plug in your camera. If the camera does not automatically find the driver, you may have to follow some prompts to point it to the driver you copied to your hard drive.
This does not cover every possibility that you may encounter, but it covers most that situations that I have experienced when installing hardware.
Brian
Apr 17, 2010 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
When i went to get my computer fixed the person that fixed uninstalled my camera but it is built into the computer. what do i do about it.
You'll need to download the drivers for your camera from Acer's site. Once you finally get down to your model, they list three different cameras. I don't know if there's anything on your computer to tell you which one it has, so just download all three. If you install the wrong one it won't hurt anything, it just won't work. Just keep going 'til you get the right one.
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
My cam does not work on person.com but works in Yahoo MSN and Hotmail Messenger. Can anyone help me fix this probles. My cam is an in-built in laptop.
Go to this site and sign-in.
http://person.com/webcams.personals_search.phtml
then go to webcam and click on it and setup your camera so it will operate on person.com. All web cam's have to be setup on a program so it will operate properly.
Hope this helps. Bud
Dec 07, 2009 | Logitech QuickCam Communicate STX Personal...
Video- I see myself instead of the other person.
Try this and send this on to the other person.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Jan 05, 2009 | Logitech QuickCam Pro 9000 Web Cam
Vivitar Digital 10X25 Camera Binocular driver.
I found the problem and am using XP, also installed this on vista and worked equally as well.
I used the driver found here, just click on the picture of the camera
http://www.mscustomercare.com/
download, then install the driver, next go to the control panel>system>device manager> then find the device listed usually as dual mode camera, click on it and choose install the driver then choose to do it manually , browse for the folder you downloaded, and find the driver folder and select it then it will put the drivers on the computer, restart the computer, connect the camera, then choose the program called my camera that was installed when you put the driver on and it should now pic up the camera.
Hope this helps you.
May 01, 2008 | Vivitar MAGNACAM Binocular
Trying to talk to another computer with quickcam
Setup :
*NOTE: DO NOT connect the camera to your computer before installing the software.*
To install the software, insert the Logitech camera software CD into your computer's CD-ROM drive.
Or
You can download the latest vista drivers from here, this link will give you the instructions on how to download the drivers with the images.
http://tinyurl.com/6ruwav
Using the CD :
The Setup screen should appear. If it does not, please perform the following steps:
Click Start and then Run.
Type D:\Setup.exe and press the Enter key.
Follow the on-screen instructions.
Using the Downloaded file :
Double click on the setup file.
After the computer reboots, the driver installation for the camera will start. Do not connect the camera until the setup prompts you to connect the camera cable to your computer.
While the driver installation progresses, remove the camera and camera base from the packaging and mount the camera on the camera base.
When prompted, plug the camera into the USB port. You should see the following diagram to let you know where to plug the camera in:
After the installation is complete, the camera should be ready to use.
We have done the drivers installation which are needed by the computer to ecognize the camera.
Setup instructions to work with the camera :
http://tinyurl.com/585der
Hope this helps.
Good Luck.
Live, Love,Laugh.
Apr 13, 2008 | Logitech QuickCam Chat Personal Web Camera
Ezonics EZ-326 Webcam Logo
Top Ezonics Computers & Internet Experts
micky dee
Larry Maranto
John Anderson
John Anderson
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
