Question about Garden
How to remove a casement window from cinder block wall and replace it with a slide window
  • 2,100 Answers
Depends on the window, how it went in, will tell you how to get it out. They usually have a flange that nails to the wall and the siding will but up against it, some have a fin that nails up against a buck and plaster will **** up against it. Either way, you will have to remove the siding, plaster, trim, or whatever is on the side of the window and pull out the 1400 nails, take out the window, and get the new slider right back in the old hole, it should fit, most windows were standard, now days they are all custom fit to any size hole. But the bucks should still be in place and the drywall on the inside will not even be touched.
Posted on Nov 09, 2010
Water infiltration in home foundation cinder blocks walls
Ouch. Water levels are too high, or drainage away from the house and downspouts is not good. You have a lot of moisture comeing through the foundation wall.
Mar 09, 2015 | Washing Machines
Are the slide outs on a montana rv made to slide out futher than normal for replacing the main floor under it?
In some cases they will slide out far enough to repair the floor but you need to be extremely careful to prevent damage and personal injury. *I am not responsible for any damage or injury caused during repairs based on this free advice* First, you will need to remove the inside fascia, then un-staple the rubber seal all the way around and then remove the inside frame that the fascia screwed to so that the slide will go out of the opening. Next you will need to start opening the slide. Right before it clears the opening you will need to go underneath and insert blocks of wood between the floor of the slide and the frame of the slide rack and pinion to keep the slide lifted in the proper location for re-installation. now move the slide out just far enough to clear the side wall of the unit. Once it is clear of the side wall place a few saw horses and or jack stands under the outside edge of the slide to add more support. Now that you are clear you can begin the process of replacing the damaged floor. Start by pulling the carpet/linoleum back. The flooring will only be stapled down so once you remove the staples it should peel back pretty easily. Once you get to a wall you will have to cut along the edge of the wall for the flooring to release (since the flooring was installed first then the walls this will be necessary). When you are ready to reinstall you will have to use some 1/4 round trim to resecure. Once the flooring is peeled back determine how much floor will need to be replaced and mark your cut points and set your saw blade cut depth to 3/4" (you do not want to cut too deep) and make your cuts. Remove the damaged floor. Now cut some scab blocks to insert along the cut edges to where half of the block surface in under the existing floor and the other half will be under the new floor. Cut a new piece of decking and install. To install the blocks and the new deck I use wood glue and screws. If you are using linoleum flooring you may need to fill the crack and sand the floor so that the seam does not show over time. Reverse the process for installing the slide out. Good luck!
Oct 09, 2014 | RVs
Need tips to redecorate my home.
The doors and windows can play a big role while redecorating home. You can install UPVC sliding or casement windows to give a more attractive and inviting look to your home. For more details, visit: http://www.fenesta.com
Feb 25, 2014 | Exercise & Fitness
Please anyone suggest me is it appropriate to choose Casement doors and windows?
The Casement doors and windows are best to to use as they are made up of UPVC which is a cost effective and long lasting. Casement doors and windows are resistant to heat, offer you proper ventilation and they are not prone to termites. So, don't think much, just go 4 dat. If you like more casement doors and design visit http://www.lghausys.com/in/product/windows/windows-doors-global-style.jsp
Oct 26, 2013 | Heating & Cooling
Has anybody found a manual for the Amana AP095R?
The included piece is not a template, but rather the piece the vent tube clips to. One side slides into the other and that allows for it being placed in windows of varying widths. I too had your problem with a casement window. I used a piece of plexiglass and screwed the round part to it and voila it worked. With my setup I was able to close the window (Pella). I later moved it to a double hung and cut the plexiglass to size. when we go out we remove it from the window. Easy peachy japaneasy.
Jul 18, 2009 | Amana AP095R Portable Air Conditioner
I have a kenmore casement model number 25378066890. I can clean the filter easily but I want to get behind the filter to made sure the front of the coils is dust free. How do I remove the cover to be able...
you have to remove the unit from the window and unscrew the cover which will allow you to clean the inside of the evap and condenser coil and oil the fan motor if it has oilers the easy way to clean it is to take it to a self use car wash. do not use the strong spray as it can bend the fins.
Jul 08, 2009 | Kenmore Slider/Casement Air Conditioner
2004 vw beetle convertible - the inside of the convertible top near the back window has a "casement" along the edge of the fabric top that seems to attach or slide into a track near the window. mine has...
That happened to me. I tried to re-insert the window into the track but it was impossible. The dealer ordered some clips and I think I paid about $50 to have it fixed.
Jun 17, 2009 | 2004 Volkswagen New Beetle Convertible
Remove base of envision lcd monitor G19LWk
The base of the G19LWK can be removed but it takes a little work. You have to remove the black plastic case that sandwich the LCD screen. First remove all the screws on the backside of the monitor. Then, at the seam of the two casement halves, GENTLY pry the front screen frame away from the display. Work carefully all around the edge of the display to separate it a little at a time and the pull it away in one piece. Next you will find that the back casement is held to the display with plastic tabs around the perimeter. Carefully pry the tabs away from the display frame to separate and remove the back casement. Now the base mounting is exposed on the backside and held with 4 screws. Remove the screws and the base will come free. Re-assemble the casement by snapping the back on first followed by re-installing the screws. Then snap the front frame by lining of the plastic tabs and pressing the frame down evenly around the display. You are done!
Jan 30, 2009 | Envision G19LWK Monitor
Venting for portable air-condioners
They make special window units designed specifically for casement windows. They are taller and skinnier than standard window a/c's. They are no where near as common as standard window a/c's so you might have to look a little harder, but they are out there.
Jun 17, 2008 | Amana Heating & Cooling
Casement Window Placement of Unit Meant for Double Hung Windows
http://www.mrslim.com/Products/Category.asp?ProductCategoryID=24
Heres an option for you I'm afraid you cant install an a/c unit In any position other than upright. Theres a unit size and type for every conceivable application though. GL!
Jun 11, 2008 | Daewoo High Energy Efficiency Air...
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
