First of all let cartridge in the printer....
Then press Start.. it will say cartridge not recognised...
then remove all cartridge (do not turn off printer)..
then wait for 15 minutes...then again put cartridges in head...
then press start..start...start..It will recognise on 2 to 3 tries..
Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
Hi, is the cartridge NON genuine. If so, it may be damaged in such a way that the printer is not recognising the cartridge. Try putting your old cartridge back in and if the problem goes away then the problem is the cartridge and not the printer
Try to left up your new cartridge, and reinstall it. chances are your installation of the cartridge is just loosened. If your printer still won't recognise your print cartridge, there might be a problem with your printer motherboard in recognising your cartridge.
