Question about Sony Televison & Video
SONY KD32DX51U HAS TWO FLASHING RED LED,S POINTING TO A PROBLEM WITH FAULTY TRANSISTOR, IS THIS CORRECT?
    Brigadier General:
  • 8,909 Answers
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Hope this helps.
Posted on Nov 09, 2010
Sony Wega KF-WS60S1 when turned on begins with 5 green flashes then 6 red flashes
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 09, 2017 | Sony Televison & Video
29pt5301/15 chassis GR2.4AA Dead only flashing red LED standby. 148V on transistor horizontal, and 38V on transistor vertical is ok.
Check the frequency at the base of the horizontal output transistor. It should be in betwen 15.5 to 15.7 KHz. If you want more details about service help, try any service help sites. There are so many can be at internet.
Jun 12, 2012 | Philips Televison & Video
Sound, no picture, Red LED 4 flashes
Hello Thanshar, Hi, you TV has sound, but no picture. this could be several things, and let us add the red led flash. In my analysis, no picture means no high voltage is reaching the picture tube. this could be due to a bad Horizontal output transistor, and/or a bad flyback transformer. This bad transistor is causing an overload to the power supply section, causing the 4 led flash to blink. Now i want to know if you want to do this service or get professional help. if you decide to do this by yourself, this needs to be performed: the Horizontal output transistor must be checked for short, the horizontal flyback transformer needs to be tested, the deflection yoke also needs to be checked, especially to horizontal coil.
Oct 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
When turning on the screen comes on for 2 seconds, then red blinking light flashes 13 times and repeats flashing.
Standard blinking codes for Bravia sets for US only goes to 10 blinks which points to faulty or short circuited components inside whereas the Australian range of KDL's goes to 13 blinks of the LED which points to a faulty balancer and must be taken into a service department.
Aug 02, 2009 | Sony BRAVIA KDL-40V3000 Television
SONY 62 LCD GRAND VEGA HD TV
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
Dec 21, 2008 | Sony KDF-42WE655 Television
No sound or screen
8 time flash shows problem with T8005 (flyback transformer, horizontal transistor) in D board. Service manual says ...
High voltage error 8 times • T8005 is faulty. (D board)
bye
Sep 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Videoseven LTV32DA powerled flashing
try to check the horizontal transistor,resold all parts near the transistor..
Feb 22, 2008 | Televison & Video
Kids.
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Nov 23, 2007 | Toshiba 32A42 32" TV
Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Sep 03, 2007 | Denon AVR-2106 Receiver
Televison & Video Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
