Question about Casio Watches
HOW TO ALTER TIME WAVE CEPTORWV58E-2AVEF - Casio Watches
Problem with day/date changes! My casio edifice
follow these instructions off the manual below if you set the watch in wrong sequens it wont change at 12 oclock
http://support.casio.com/en/manual/009/qw5125.pdfhttp://support.casio.com/en/manual/009/qw5125.pdf
Sep 27, 2013 | Watches
How to fix the time and date
unscrew crown pull out to first position turn crown to alter date, pull crown out to second postion to alter time push crown back in and screw down
Mar 04, 2013 | Watches
I have a model 31420E skyscan & have lost the instruction manual. Also I live in Sydney Australia and don't know anywhere here to get help.
I couldn't find the manufacturers' web site but I found the following , which may help;-
The unit automatically receives the time signal everyday at midnight and makes any required adjustment to the time displayed.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
Dec 20, 2010 | Watches
Seconds out of sync on waveceptor
Hi!
press the lower left button until "H-S ET" appears, then press upper left button for 3 seconds ("-0 0-" appears on the screen), press lower right button for adjust the seconds hand
Nov 29, 2009 | Casio Watches
New battery fitted 2 weeks ago, day date are correct time wrong
still working on it via the manual from casio website, thanks
Apr 01, 2009 | Casio WVQ600DCA Wave Ceptor Watch
How to switch wave ceptor back on after fitiing new battery
Find it here:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 29, 2009 | Casio Watches
I dont know how to set time
Some 70s quartz watches used quite a different system where you push the crown in, hold for a while (perhaps 5-10 sec) then release it and push and hold it back in again immediately. At this point, the ends should set off advancing at many time their normal rate so you can alter the time.
Complex, I know.
Feb 01, 2009 | Bulova Watch
Watches Logo
24 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
Dennis Fitzsimmons
Level 1 Expert
Are you a Casio Watch Expert? Answer questions, earn points and help others
