Question about AutoCommand Remote Car Starter Add-On
The remote start works (starts the vehicle) only when the fob is very near (inside) the controller.
  • Alan H Nov 10, 2010
    Are you using the factory remote fob or do you have an aftermarket system installed? What year, make and model is your vehicle?
  • randy_hovatt Nov 10, 2010
    I am using the factory fob with new batteries. The unit is in a 2004 Kia Sorenta and has been working flawlessly until now.
  • 139 Answers
First check the battery voltage. A good new battery will be about 3 volts. If it is significantly less, get a new battery and retry. Examine the battery contacts since you have the remote apart to ensure that they are clean and shiny. If they are dull, use a pencil eraser to clean the contacts. If you are still getting poor range you can try to reprogram the remotes to the OEM keyless entry system. The procedure follows.
Transmitter Code Programming
Note: The receiver (ETACS module) can save maximum two codes from the transmitter.
1. Apply the battery voltage to the terminal "6" of DLC (Data Link Connector),{see attached image}. The DLC is located on the left side rear of the engine compartment. The wire color for terminal #6 is red/black.
2. Turn the ignition switch to "ON" position.
3. While coding one transmitter.
Press the lock button of transmitter for 3 seconds over until the turn signal lamp turns off.
4. While coding two transmitters.
Press the lock button of one for 1 second while the turn signal lamp turns on, and then press the lock button of the other for 1 second over until the turn signal lamp turns off.
5. Remove the battery voltage, and then the transmitter code is re-saved on the receiver.
6. Check the operation of the keyless entry system.
If you still experience poor range, you may need the system serviced or the remote replaced.
Posted on Nov 10, 2010
How do i find out if vehicle has remote start feature ? all functions on key fob work except engine crank even park lights flash indicating remote start feature . maybe a fuse blown or not in place.
How to check if your GM car is equipped with factory keyless ...
blog.remotesandkeys.com/.../How-to-check-if-your-GM-car-is-equipped...
Aug 25, 2011 - Many, but not all GM vehicles, are equipped with factory keyless entry. ... If not, and you want to have remote keyless entry, go to an alarm shop or Best .... Your other option is to locate the aftermarket receiver under the dash and ... start but need programmed or how can i check if i have remote start installed.
Remote Start ' Vehicle Features ' Official Ford Owner Site
owner.ford.com/.../vehicle-features/.../remote-start-...
Ford Motor CompanyIf your vehicle has automatic climate control, you can configure it to begin operating when you remote start your vehicle. A manual climate control system will run ...
Factory Remote Start Installed? - Chevrolet Forum - Chevy ..
Jan 14, 2016 | Cars & Trucks
Why are my key fobs not working on my 2006 Chevy Monte Carlo XLT?
2006 Chevrolet Monte Carlo Key Fob Remote Programming ...
blog.keylessentryremotefob.com/.../2006-chevrolet-monte-carlo-key-fob...
Mar 27, 2014 - 2006 Chevrolet Monte Carlo Key Fob Remote Programming Instructions ... If you need an extra Key Fob or Replacement Fob for any vehicle ... Donot start the car. ... ****IF ANY OF YOUR REMOTES STOP WORKING AFTER ..
Oct 16, 2015 | DSC Wireless Key Fob
Have 2010 colbolt green light on fob car won't start doors won't lock or unlock
On my car you can put the fob in a little compartment inside the glove box and it will allow the car to start.
You need to "pair" the fob to the car. The procedure should be in your owners manual.
Jan 11, 2015 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Programming keyless fob
Yes. Nearly all sophisticated electronic components in a vehicle have a constant power lead that goes straight to the battery positive lead. The only time this power source is interrupted is when the battery is disconnected from the positive and negative main terminals of the car. Which usually only occurs when an aftermarket installation occurs. Like when that new stereo was installed. Therefore you have a situation where the memory that held the code information for the door fob got erased when the battery was disconnected because it lost all power. This sounds like a reprogramming issue. Contact the fob manufacturer, which may, or may not be the same as the entire car manufacturer. They will provide instructions on how to re-program the unit which is usually very simple.
Sep 18, 2017 | Car Audio & Video
Rocker switches,nor remote will lock or unlock doors fuse good
So , the power door locks won't lock or unlock with switches inside the vehicle or with the keyless entry remote fob.??? Is this correct ????
Do you know what a BCM - body control module is ? Do you know what diagnostic trouble codes are ? If not your best bet would be to take your vehicle to a GM dealer or someother qualified repair shop.
DTC B3142 or B3143
The body control module (BCM) provides an output to the driver switch assembly through the door unlock control circuit for controlling automatic door unlock, anti-lockout, and keyless entry unlock functions.
DTC B3152 or B3153
It could be the driver door master switch , could have broken wires inside the rubber boot from the body to the door . Do the power windows work ?
The keyless entry system has the following main components:
• The transmitters
• The body control module (BCM)
When you press a button on a transmitter, the transmitter sends a signal to the BCM. The BCM interprets the signal and activates the requested function.
How did you do this ,,checked and made sure locks and remote programmed,they were,but still do not work ?????
Need a scan tool to program
Important: All key fobs must be programmed each time any one fob is programmed. The scan tool must stay connected until all of the transmitters are programmed.
Install a scan tool and navigate to the BCM Module Setup menu.
Select Program Key Fobs.
Follow the scan tool on-screen directions.
When the programming operations have completed, operate the transmitter functions to verify correct system operation.
Aug 09, 2017 | 2005 Chevrolet Colorado
How to program key fob for 2011 hyundai santa fe
Nonsense. I just programmed a new remote start fob on my 2011 Santa Fee limited and it worked just great. Follow the steps below and see what happens.
1. Open the drivers side door
2. Turn the Vehicle ignition to the ON position (Do not start the vehicle)
3. Locate the disarm/program button. (look closely, it is located on the wiring harness just inside the lower dash. it could be located just inside the fuse cover.)
4. Press and hold the disarm/programming button for 10 to 15 sewconds, the horm will beep 3 times. Release the disarm/programming button.
5. On the fob, press the Find/Panic button One time and the horn will beep one time.
6. Turn off vehicle ignition. (YOUR DONE)
Jun 08, 2012 | 2011 Hyundai Santa Fe
Vehicle wont start
what type of vehicle?
Jun 06, 2012 | Cars & Trucks
I replaced the battery in my key fob and now the remote start will not work it pops the trunk open. How do i get the remote start to work again?
If it pops the trunk then the unit is still programmed correctly to the vehicle. I would open it and check the buttons and ensure you didn't pinch them and they are still making contact with the pads inside key fob. Probably just stuck after closing the remote.
Nov 11, 2011 | 2006 Chevrolet Impala
Car will not start using the key fob all fuses are good, lock/unlock buttons work. i have had this remote starter in this car for nearly 3years
In some cases, if you hold down a button too long on the remote fob, the starter module goes into a setup "menu", which is possible. You didn't change the fob batteries lately, did you? It sounds like you will have to 'retrain' the fob with the starter unit so that it re-learns what to do when you push the start button. With the "Ultra" brand, you use the button on the windshield antenna to retrain your unit. I'm not sure about the Autopage brand. An installer should be able to reprogram it for you for $10, and that would be the easiest if you can't find the data by doing a Google search.
Oct 02, 2009 | Autopage Vehicle Parts & Accessories
2004 isuzu rodeo won't start
ok, first of all batteries are not expensive, they are priceless when you need them. Your remote will work best if you make sure the battery is in full clean contact with the tangs inside the battery spot on the remote. keep the insides clean with an old toothbrush and some rubbing alcohol. ( the fob, not the battery ) .. if its a money issue, you can look for alternate sources for your battery needs, like goodwill in the electronics section, the battery used in most remotes is a common 2016 or a 2032 battery.. they are all over the place in other electronics. Hope this helps. BUY NEW BATTERIES.
Mar 26, 2017 | OEM Systems Vehicle Parts & Accessories
AutoCommand Remote Car Starter Add-On Logo
246 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
