Question about Ricoh Aficio CL3000 Laser Printer
Ricoh CL3000 error sc441 - Ricoh Aficio CL3000 Laser Printer
  • 903 Answers
Sc441 is a drum motor error. It could be caused by anything from a faulty circuit board to a bad motor, but the most likely fix (and the easiest) is to replace the color PCUs (photoconductor units) which I believe all come as one set.
Turn the machine off and unplug it from the wall, then install the new PCUs, plug it back in and turn it on. There's a good chance your printer will work fine. If the sc441 error comes back, you should contact your local service company and have them take a look at it, because the problem is either electrical or mechanical.
Hope that helps!
Posted on Nov 16, 2010
2 Suggested Answers
  • 903 Answers
SOURCE: My RICOH AFICIO CL3000 give
Did you just replace your color PCUs (photoconductor units)? If so, one of the new units may be defective. Try reinstalling the old units to see if the problem goes away (after resetting the machine). If it does, you can replace the PCUs one by one to see which one is bad.
If you still get the sc441 even with the old PCUs (or if you don't have them anymore) install a set of new PCUs and that should fix the problem. On the off chance the problem doesn't go away even with new PCUs, contact your local service company because you may have a bad circuit board, motor, or gear.
Sc-486 on the Ricoh Aficio CL3000 printer
sc486 is a problem with either the engine control board or the drive unit, or the connection between them. One or the other will probably have to be replaced, depending on exactly what's causing the problem.
Mar 22, 2011 | Ricoh Aficio CL3000 Laser Printer
My RICOH AFICIO CL3000 give me an error message SC441, what to do ?
Nov 15, 2010 | Ricoh Aficio CL3000 Laser Printer
Has bee my default printer until now. Connection to router is fine, will not print - only gives error message. none of the buttons on the control panel work. online light is out. is this a big fix or...
go to the control panel, select printers and double check if the Ricoh Aficio CL3000 Laser Printer was selected as a default printer. you can check it by right clicking the printer name and choose set as default.
Sep 13, 2010 | Ricoh Aficio CL3000 Laser Printer
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Jan 21, 2010 | Office Equipment & Supplies
Error message on a Ricoh 2000 SC441. What does
SC441 mean scanner or laser unite problem.Open it and clean laser mirror,or clean scanner door sensor.
Dec 09, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh c3000 replace fuser error
try to unplug it from the wall and plug it back in and let me know if this works
Feb 02, 2009 | Ricoh Aficio CL3000 Laser Printer
Ricoh CL2000N Error SC441
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Jan 08, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh 3500N - Photoconductor Problems
I thought the SC441 error was a "Drum Peripheral Component Motor Lock", have you tried cleaning in and around the drum. Maybe the motor is going bad or there's some kind of obstruction.
May 22, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh Aficio CL3000 Laser Printer Logo
843 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
