Question about Vacuums
My daughter dopped the remote for my digi box, digihome dv940b into a cup of tea it now dosnt respond. Is there any thing i can do?
    President:
  • 1,140 Answers
It's best not to test them after immersion in liquid and it's probably a lost cause, but you can try this:
1. Remove the batteries
2. Gently split the top and bottom halves of the remote apart with a flat-head screwdriver
3. Dry inside the case and the circuit board with some kitchen towel - don't rub the circuit board just gently dab it.
4. Leave the remote somewhere warm for at least 48 hours with the case still in half.
5 Re-assemble the case and insert new batteries
6 Test.
If it still doesn't work or the buttons function incorrectly, unfortunately you will need a new remote.
I once spilled a can of coke over an Apple keyboard and washed it out under a tap. I left it to dry for a week and it worked, but that was mostly luck rather than any technical wizardry!
Hope this helps,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Posted on Nov 09, 2010
How do I get my sat box to respond to remote control
First, check whether you have the correct remote control for the box, then make sure the battery is good and properly installed. Also, verify that the remote control pickup window on the box is clean and is not covered with a sticker,
Sep 21, 2014 | Vacuums
My Keurig coffee maker is not brewing. The word prime is on the screen. How do I prime the unit.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 14, 2011 | Vacuums
My grey & purple steam mop is getting very little steam at the head. is there a way to clean it without damaging the product? or is there another solution for low steam?
Mixing white vinegar with water about a cup of vinegar and a cup of water ratio and let it steam through the mop. This is also good for steam irons and other appliances such as coffee/tea makers. The acetic acid in the vinegar will dissolve the calcium build up that blocks the steam ports and will not hurt plastic or floors. If you object to the vinegar smell, then mix a little lemon juice with the last cup of water and this rids you of the vinegar smell. I use the white vinegar to mop the wooden floors in the house.
Apr 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi, my husband bought me your KAMENSTEIN WORLD OF MOTION SERIES ANIMATED HORSE CAROUSEL many years ago. I did not keep the box or manual and now I want to ask can you e-Mail me a download or one I can...
I cannot loacte an actual manual but....The Kamenstein Carousel teapot was part of the MKI versions of teapots Kamenstein released in the mid-2000s. The teapots came in a range of colors, from blue to red, and they had a small carousel on the top. As the water boils the carousel spins around, bringing an element of whimsy to your tea time. The teapots are all metal and can be used on any type of stove top.
Instructions
    • 1 Fill the Kamenstein Carousel teapot with water just below the sprout.
    • 2 Place the Kamenstein Carousel teapot on the stove and set the heat to "Medium."
    • 3 Allow the water to come to a boil and remove the Kamenstein Carousel teapot from the stove.
    • 4 Pour the hot water into a cup over a tea bag.
Read more: How to Use a Kamenstein Carousel Teapot ' eHow.com http://www.ehow.com/how_7718254_use-kamenstein-carousel-teapot.html#ixzz1JAQxUJn2
Thanks
Apr 10, 2011 | Vacuums
I DON'T HAVE INSTRUCTIONS FOR A TM4 MR. COFFEE ICE TEA MAKER I BOUGHT AT A THRIFT STORE TODAY. I DO NOT KNOW HOW IT WORKS. I PRESS THE BUTTON AFTER ADDING WATER TO THE WATER LINE BUT IT CLICKS OFF...
I just got the exact IcedTea maker that you have (model TM4) from Mr. Coffee. I think that we were both trying to make it work the same way, which is wrong. The plastic pitcher goes on the bottom, while the part that plugs in with the button&indicator light goes on the top. Put water in the pitcher to the indicated water line and then pour it into the part with the metal basket. I didn't have any directional sheet either so I didn't know that the water goes in there. I thought the water would be gently warmed while in the plastic pitcher. After pouring water into the heating part, fill the pitcher with ice to indicated level (about 2 ice cube trays). Place the heating part with the button&indicator light on top of the plastic pitcher and cover it with the white lid. Push the button and it will heat the water and dispense the brewed tea into the pitcher thru a valve. The indicator light will go off when the brewing process is done. The entire manual can be downloaded from going to: http://www.mrcoffee.com/manuals/MrCoffee/tm4.pdf I hope this helps you if you still have the item. I bought mine to give my daughter while in college. I really like that it is so space saving compared to many that I am finding in stores today. Good luck and happy brewing!!! Susan
Mar 05, 2011 | Vacuums
I have a gemmy incredible light show trio, daughter dropped remote in dogs water bowl now it wont work, can i get a replacement remote for it? thanks Mike
you can buy a remote at holidayinflatablestore.com for 20.00 I just ordered one myself they have 61 left click on the accesories and parts on the left.
Nov 17, 2010 | Vacuums
I know this is probably a stupid question, but I don't know how to open the dirt box to clean it. I put the lever on open, but then I don't know which way to pull.
The dirt cup sits in a small recess on the shelf that lifts it up and down. Dust gets in there and makes the cup stick to the shelf. With the lever in the open position, hold the shelf down with one fingernail and lift the cup up. once seperated, cup should pull straight out.
Aug 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka Altima
The dust cup has a small gray tray that appears to be part of the cup, but is not. I made the same mistake also and almost broke the stupid thing trying to get it out. Simply push the lock to the left to unlock. Gently lift the dust cup and not the gray tray and the cup will slide out easily.
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum2.jpg[/IMG]
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum1.jpg[/IMG]
Oct 01, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
73 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
