Question about Sony STR-DE497 Receiver
The problem is the protect mode cannnot removed
How do i replace the battery
since samsung galaxy tab is come with non removable battery, you cannnot change or remove its battery. If you battery get damaged or weak you can get it chnaged at your nearest samsung mobile service centre. Thanks
Dec 06, 2014 | Samsung Tab Tablets & eReaders
Cannnot play dvd's bought in a different country.
That is because DVDs are set up to play in only one set of countries. North America is Region 1 UK is a different Region. This is to stop piracy and to protect each countries laws on intelectual property rights.
Feb 22, 2011 | Televison & Video
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I cannnot play videos on my console that are stremed from my computers.
The videos may be in the wrong format. Try WMV with no DRM on it, or an AVI with no DRM. If that works, than the file format may be un-streamable or the Xbox doesn't like it because of DRM protection.
Feb 08, 2010 | Microsoft Xbox 360 Console
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
My Sony receiver is flashing protect mode
Disconnect all speaker wires at the receiver. Then power the unit on, if it stays on, post a comment on this thread and I will help you troubleshoot further. If "Protect" remains on, you need to have your receiver serviced. Hope this helps.
Aug 23, 2009 | Audio Players & Recorders
Canon imageclass MF6530
try ( add.function & #) service mode and then find clear all
Feb 26, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
My samsung HT-TX75 keeps shutting off in a few minutes saying protection.
protection mode activated to protect from serious damage and please follow me.1-shut down your system2-make volume in low position3-remove all your connected speaker4-switch your system on and watch if it does not go to protect mode insert your speaker one by one until you find the bad one and change it and start with cable change first and then speaker itself-if it goes to protect mode you must call service center.
Jul 07, 2008 | Audio Players & Recorders
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Sony STR-DE497 Receiver Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
