Question about HP DeskJet F380 All-In-One Printer
Hp F380 Completely dead. NO LED Glows. Powere supply socket gives15V & 33V. There is no fuse inside.. Please guide
Throw it away. There's no way to repair those printers.
Posted on Nov 09, 2010
HP Designjet 500 has a locked screen. I have been trying to get the plotter to run on our new computer and it locked up after installing the current Firmware and driver updates. Any suggestions would be...
Dear Friend, It's a serious issue what I understood & confusion is control panel locking facility not avail in this model, how its locked?.. Simple method to catch the faulty part through power LED behaving s..(Power led located on power button)
# LED is OFF - This indicates that the Power Supply Unit is
completely dead. Try the following:
1 Check that power cord is connected correctly to the Printer and to the Power Socket.
2 Replace the Power Supply Unit
# LED is ON (all the time) - This indicates that the Main PCA is completely dead. Replace the Electronics Module
# LED is Flashing - A problem has been detected with the previous firmware upgrade. Try re-send the firmware upgrade file.
# LED Flashes twice every few seconds - The Printer cannot detect the Interconnect Cable. Try the following:
1 Check that the Interconnect Cable is connected correctly to the inter connector PCB & Electronic module.
2 If the Interconnect cable is connected correctly and the LED continues to flash twice then replace the Interconnect Cable
LED Flashes 3 times every few seconds - The Printer cannot
detect the Front Panel. Try the following:
1 Check that the Front Panel is connected correctly to the Interconnect PCA.
2 If the Front Panel is connected correctly and the LED continues to flash 3 times then replace the Front Panel
LED Flashes 4 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module
LED Flashes 5 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module.
Now U decide that whether firmware uploaded properly or not?..if not its sure that Electronic module gone.. you have 2 replace it..
Any further help/query pl reply, best of luck..
Oct 02, 2013 | HP DesignJet Office Equipment & Supplies
How to dis ismbel lp laptop made in 2008
There is no fuse inside the HP laptop.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 04, 2013 | HP Computers & Internet
Dead toshiba satellite laptop
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 01, 2012 | Toshiba Sattelite A105-S2071 Notebook
My HP 2800 is completely dead. I bought a new power supplay but again nothing..... Please help me !!
Ypou maybe right and it is dead. Try other options like what happens when you plug it in. Listen to it when you do that. And please, I do not mean anything here....but does the power supply have a light that glows when you plug it in?
Nov 02, 2010 | HP Business InkJet 2800 Printer
I have been given an HP Deskjet F380, but the disk ti install it has been lost, can i install a prog from online so that i can use it???? & are these online progs trustworthy???...meaning will i get...
Please find the link to download your free set of software/drivers from the HP link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=1128296
Just select the operating system you use, and start the download.
The above link is completely safe.
PLease rate the level of assistance provided.
Mar 30, 2010 | HP DeskJet F380 All-In-One Printer
DEAD SET NO LED NO CLICK JUST DEAD
hello check glass fuse inside if it's black it's blown if you put another 1in and it blows again then you have a dead short somewhere the fuse will be in the power supply might be rated at 2.5amp or 3.15 amp good luck
shaun
Nov 02, 2009 | Televison & Video
When I plug it in to the powere cord no lights appear to show that it is charging. Is it completely Dead?
pull the battery and check it with a dc power meter that measures voltage if you got low/no power you'll have to buy another battery/ also try using the power cord w/o the battery installed. it theres no light anywhere means the ac power converter /supply has died.
Jul 09, 2009 | HP Pavilion ze2000 Notebook
No power on tv
I'll think there's a problem with the power supply.
Maybe there's a blown fuse inside, that would be the cheapest solution. If not, you need a repair centre.
Kind regards,
Gerard
Jan 25, 2009 | LG 42LC2D 42 in. LCD HDTV
HP F380
the problem of the printer is when you turn-on the printer it automatically print...then the paper goes inside the printer and when it goes out there is nothing been printed out....what should I do....my printer is F380..thanks
Oct 28, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
