Question about HP Compaq Presario SR5450F Desktop PC
Mobo fried? Beeps when startup but no video. I reseated ram and video card, with no luck. Both fans work and it sounds like it is booting. I tried older video card too but nothing. Thanks for any responses.
  • 1,179 Answers
Try removing the display card and using the onboard VGA. Remove the BIOS/CMOS battery for about a minute and then reinstall it in the correct orientation. This will reset the BIOS/CMOS to it's default settings. You say it beeps once, this means that it is fine the mainboard is ok, it is not experiencing any problems. If it beeps in a continuous manner then it is the RAM that is causing the problems, I would say that the default settings may solve your troubles. Remember to enter the BIOS/CMOS when during boot up to reset the date and time by hitting the delete key. Also try entering the BIOS/CMOS even if you can't see any thing on screen, by doing this it may come up. let me know how it goes, I am here to help.
Thanking you
damnor01
Posted on Nov 09, 2010
  • jose de jesus sigala Jul 04, 2011
    i was going to say the same and i want to add some more you can try with a different power supply it sometimes works....due an low voltage some its jus monittor doesnt come..and you should try even before you try a dif psu with a diferent monitor...i had an issue with an ATI RADEON 256MB THE BIOS OF THE RADEON WAS DAMAGET AND NO IMAGE CAME I SWAPED BY ANOTHER AND VOALA IT WORKED FINE...I HOPE IT CAN BE USEFUL TO YOU... DONT FORGET TO COMMENT AND VOTE ME THANKS
Dell D600 won't boot
I am sure Not the CPU or fan problem. Follow the below step to repair it.
1. Just press the power button 5 seconds or more to see the laptop can reboot or not. 2. replug the memory modules. 3. maybe the power supply device failed that the electronic volt is not enough to boot the laptop. Just replace a new Dell latitude d600 battery power supply.
Jul 28, 2010 | Dell Latitude D600 Notebook
My mobo doesnt beeps nor video output
your bis/firmware will be corupted.download latest firmware in bootable cd format and update bios.even if mb doesnot give display it can boot and flash the bios.(follow website for details on how to make cd-iso)
May 27, 2010 | Biostar MCP6PB M2+ Motherboard
PC will not power up. No fans, lights, anything.
Have you tried a different power cord? (longshot, I know, but it is one of the variables that you don't mention)
Have you tried a different A/C outlet?
Dec 22, 2009 | Computers & Internet
Motherboard no responce
When you turn on the PC, normally the boot codes start at 00 and go up to FF (ex 00, 01, 02 etc..).
1.remove the ram memory and video cards if any .. 2. check and reconnect the power suppy wires for mother board , 3. dont worry about your operating system ...no data is lost . 4. if u have not heard any beeps while booting then ...it could be the ic chip ...reseat it properly and make sure it is properly locked . 5. check the fan ...the chip can will over heat when the fan malfunctions ..
this should help ...based on info provided by u , provided u take atmost care while opening or reseating the mobo items
good luck..!
Oct 26, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
My pc doesn't boot anymore.
This code usually refers to a Video card or RAM issue. Try reseating both the video card and then RAM to see if it fixes the problem. If not then try removing the video card and rebooting. If the system starts without the beeps then you'll know the video card is bad and you can replace it. If it still beeps then try removing the RAM one stick at a time, rebooting after each removal. When it boots you'll have the bad RAM stick isolated and can replace. Hope this helps.
Oct 11, 2009 | ASUS P4P800-VM Motherboard
Turn on Pc and I get 3 beeps and it shuts off
make a clean the memory or replace the memory
May 23, 2009 | DFI AK74-SC Motherboard
NO VIDEO OUTPUT
Sounds like a dead motherboard, i had the same problem a while back, with my custom built pc, that or try a new power supply. but i'd say it was the mobo though. a new one cost as cheap as 40 bucks i'd say depending on what your hardware is, you friendly neghborhood pc shop can help you, fyi, build your own pc its cheaper!
May 12, 2009 | Computers & Internet
One short beep two long beeps redlight on startup
RAM usually goes in pairs. Do tests with two sticke. They have to be identical
Jan 11, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
HP Compaq Presario SR5450F Desktop PC Logo
301 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
