Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
I have the the door alarm beeping and door isnt even opened. Plus now the water and ice maker on the door isnt working? I need help
  • Maytag Master
  • 2,696 Answers
There's a board behind the touch pad on the left door part number 67006294 and it's around 70 bucks,unplug the machine when working on the machine
Posted on Nov 09, 2010
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
The door alarm and the fact that water and ice in door is not working points directly to a problem with the door switch: (Item 19) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167242&diagram_id=1329453#d1329453
The drawings are a bit confusing on the site but the switch you need is this one:
http://www.appliancepartspros.com/part_details.aspx?part_id=4008827
Per the parts list this switch is actually located on the left side of the left door. You release the tab with a thin knife blade and pop out the switch. Do a one for one wire transfer of wires with the replacement switch. You can read the switch out with a meter by reading the common to one terminal plunger out and from the other terminal to common plunger depressed. I am pretty sure this is your problem Read it out.... change the switch if it is bad and everything should be back to normal. No more than the part costs I would order it before removal and just swap it out doing the one for one wire transfer at that time. The new switch once the terminlas are connected just snaps into place by pressing it in to the side of the cabinet.
Thanks for choosing FixYa,
Kelly
  • Kelly
    Kelly Nov 10, 2010
    I am not saying the other expert that replied to your question is incorrect but I would most definately make sure the door sqitch was working properly before I went out and bought a control board. You have to isolate the problem and performing the door switch continuity test with a simple Ohm meter may very well save you some serious cash. Until the door switch is eliminated as a suspeced failure.... to me the control boad is out of the question. There are 2 different door switches. One has 2 contacts (wrong one) and one has 3 contacts (correcxt one). If there is a door switch problem in will be the 3 contact switch. Just a note that still does not eliminate the door wiring as a possible suspected failure. (Rare that the wiring is the problem but if it does cause the door alarm / water and ice in door problem, the actual wiring problem is usually is found in the door hinge area where the wires pass)
    Kelly
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Was useing the water....then the door alarm came on and now the water and ice maker is not working
try this ,in the back of freezer there is a tube that feeds ice maker sometimes it freezes up aim a hair dryer at the tube for 5 to 10 mins ,not to close or it will melt
Apr 13, 2013 | Maytag MFI2266AES Stainless Steel Bottom...
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
I have a whirlpool Magic plus ice maker that is not working. The water doesn't not fill tray. No ice.
You should disconnect the refrigerator and wait until all the ice melt. Better if you open the door of your freezer. Not need to open the door of the refrigerator. Then connect it again and the device wil start working
The other way is to take off the cover of the ice maker and clean all the ice that can be obstructing the device to return to his inicial position that release the entry of the water.
Apr 12, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
150 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
