Question about HP LaserJet P3005 Printer
Stander top bin full remove all paper - HP LaserJet P3005 Printer
  • HP Master
  • 1,121 Answers
Top bin sensor disty, clean it
Posted on Feb 03, 2012
jaylex
  • 417 Answers
SOURCE: standard top bin full remove paper
Hi there is seems that the machine thinks there is too much paper at the paper printout exit. If there are printouts on the top of the printer remove them and the printer will start printing or the error message will go away. If there is nothing on top of the printer then where the paper comes out after it has printed you will see a black plastic lever type it is more likely to be in the up position without breaking it if it hasn't already been broken move it so it is in the down position it is on a hinge so be careful and it should sit at an angle. Once this has been done the printer will reset the message itself.
Hope this is help you oh if the arm is broken it will need replacing (just the arm)
Thanks J
Posted on Jan 13, 2008
checkitright
  • 1362 Answers
SOURCE: Hp 3800dtn standard top bin full remove paper error
top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
Posted on Jul 21, 2008
  • 49 Answers
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Posted on Feb 27, 2009
  • 46 Answers
SOURCE: when i try to print its comming up standard top
either the paper switch at the exit is stuck or the light barrier is bad or the cable came off
Posted on Oct 23, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: standard top bin full remove all paper from bin
Check the sensor flag where the paper exits the printer and make sure it is not stuck in the "up" position. This is a small black plactic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP says to "flip" the sensor flag up and down to make sure it is not stuck.
Good Luck
Posted on Nov 25, 2009
Printer shows standard top bin full
Where the paper exits, there should be black tabs that lift up each time a page exits. They might be stuck in the up position, or possibly broken. Usually caused by aggressive removal of a paper jam.
Sep 24, 2014 | HP LaserJet 5200 Printer
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Standard top bin full?
I suggest you remove any sheets of paper from top tray then lift up and release a black plastic flap found under a plastic overhang on paper exit tray. This lever (If its not broken/missing), should be free and should drop down(under its own weight) freely. If not then it will involve using the manual to remove the top cover and find where lever is jamming (usually jumped out of a guide bearing.)
regards
carmike
Feb 17, 2014 | HP LaserJet 5200tn Printer
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
Sep 21, 2011 | HP Hewlett Packard LaserJet 5550n Printer
HP Laserjet 5200 top bin full
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
Apr 18, 2011 | HP LaserJet 5200 Printer
Standard top bin full remove all paper from bin
Good Luck
Nov 25, 2009 | HP LaserJet P3005 Printer
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Don
Nov 04, 2009 | Lexmark T634 Laser Printer
Standard top bin full remove paper
Greets!
Feb 26, 2009 | HP LaserJet P3005 Printer
Jun 27, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet P3005 Printer Logo
Clive
Clive
