Question about Philips 19PFL3403D/F7 LCD TV
19PFL3403D/f7 service manual - Philips 19PFL3403D/F7 LCD TV
2 Suggested Answers
  • 102 Answers
SOURCE: 19pfl3403d/f7 rolls constently thru the channels
If it does this, even when the remote control is in a different room (or has the batteries removed), you need to have the set serviced by a professional.
If it only happens when the remote is nearby then you may actually have stuck keys or the equivalent shorting inside the remote. Some remote cases open easily and you can blow out the inside and under the keys with "canned air" spray.
If the problem is with the remote, you can buy a cheap replacement at a local drug store. They will be labeled "universal" remote. However, no remote is truly universal. Check the label on the package and verify online that the device will work with your brand of TV BEFORE you buy.
Never open the case of a CRT or Plama television as there are LETHAL voltages inside for WEEKS after the set is unplugged.
Posted on Jan 02, 2010
39MF412B
Try Toms Service Manuals. Saw this on search for that model and the words "service manual" but you can also say "schematic" and maybe find something. You can sometimes buy them online also.
Welcome to the TV Monitor Service Manual Database magnavox 39MF412B F7 problem Badcaps Forums
Jul 12, 2014 | Televison & Video
Tv will not turn on
If the LED lights up and turns green or stays red then you have a power supply problem
Dec 08, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Where can I obtain Power Supply for Phillips 19PFL3403D, since my unit has no power or standby light...???????
Check the power source?Yes,than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Jan 02, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Model 19PFL3403D/27 having trouble powering on the TV. Even after pressing the POWER button the the side of the TV and toggling from OFF to either STANDBY or ON. It should not be this difficult just to...
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Philips tv 19pfl3403d/f7 instructions for switch to digital, i took off antenna how do i scan for digital channels? do i need seperate wires hdm1 wires ?
Philips 19" Model # 19PFL3403D/F7 I sometimes have to unplug it from the power source for a while to turn it on. Do I need to replace the whole board #715T2906-3, also there are similar boards 2906-2 & 2906-4 will these also work. Thanks
Jun 14, 2009 | Philips VOIP0801B/79 IP Phone
My Philips 19pfl3403d/f7 wont turn on without unplugging first.
just call philips and they will send you a new t.v.! it isn't a recall, that would be bad publicity!! i spoke with a philips representative yesterday concerning my 'possessed' television. a gentlemen informed me that philips has a 'rapid replacement program' for the described 'possessed' t.v. set. simply provide model and serial numbers, time and place of purchase, then provide street address for fed-ex delivery. approximate time of arrival is 10-15 days. you are directed to package and return the old set to nearest fed-ex pick up site. i am super excited that i took the time to call philips support. i think that i spent a total of 10 minutes on the telephone; it was time well spent. oh yea, here's the number!
Speak with a Philips representative
1-888-744-5477 Monday - Saturday 8:00 am - 11:00 pm EST Sunday 9:00 am - 6:00 pm EST Excluding major holidays
Mar 31, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
F7 alarm
I believe "F7" is a function key error with the Electronic Range Control (ERC). The ERC is not serviceable, so it will have to be replaced. If you can provide me with the model number off the range (usually located on a label inside the lower drawer), I can provide you with a part number. I hope this helps.
Aug 07, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Philips 19PFL3403D/F7 LCD TV Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
